Продолжение темы. Старая тема по ссылке
http://www.cqham.ru/forum/showthread...=1#post1549667
Вот интересный материал относительно того, каким образом можно было бы определить номиналы резистора и конденсатора "гридлика":
http://www.antiqueradios.com/forums/...60023&start=20Скрытый текст
Цитата:
Here's how I determine the values for the grid capacitor and leak resistor for the regenerative detector -
1. Make the value of the grid capacitor (condenser) around ten times the total input capacitance of the tube grid (grid to plate plus grid to cathode). This makes the impedance of the capacitor, at the carrier frequency, small in comparison with that of the grid.
2. The time constant of the grid leak and condenser should be no greater than one fifth of the period of the highest modulating frequency to be reproduced, in order for the grid voltage to follow the modulation envelope quickly enough to not reduce the amplitude and distort the waveform of the recovered modulating frequency excessively.
Using these guidelines, the values can be determined:
1. Choose the condenser value:
For example, the grid input capacitance of tube type '01A is published as very close to 11 pF. So, 10 x 11 = 110 pF. The closest common value is 100 pF, it will work perfectly well here.
2. Calculate the maximum value for the grid leak:
If the highest modulating frequency to be reasonably well reproduced is say, 3500 Hz, then 1/3500 = 286 uS. 286/5 = 57 uS. 57 uS divided by 100 pF = 571,429 ohms as the maximum for the grid leak. The closest standard 10% value is 560 k.
So, 100 pF for the condenser and 560 k ohms for the grid leak are suggested, in the example case given.
Of course, experimentation with values up to two or three times higher and lower may be appealing so as to develop a feel for the effect they may have on the audio, regeneration control, sensitivity, etc.
Краткое содержание, суть:
1. Величина емкости ориентировочно в 10 раз выше, чем суммарная емкость (сетка-катод + сетка-анод) лампы.
2. Величина сопротивления выбирается исходя из постоянной времени RC-цепочки гридлика, которая должна составлять не более одной пятой периода максимальной частоты модуляции.
Пример:
1. Для лампы 6Ж8 емкость гридлика составляет примерно 10 х (6 + 7) = 130 пф.
2. Для этой же лампы и максимальной частоты модуляции 6кГц (период = 1/6000 = 167мкс, одна пятая будет 33мКс, делим на емкость 130 пф, получаем максимум 254 кОм.
Это те ориентировочные значения, с которых нужно начинать, а практическое изменение этих параметров в 2-3 раза туда-сюда подскажет, как получится лучше.
При макетировании можно использовать набор емкостей и сопротивлений, коммутировать джамперами в любой комбинации. И пробовать при различных режимах каскада.
Поздравляю всех с 8 веткой темы!:пиво::пиво::пи во:
и днем ВМФ
Сообщения ранее об отборе ламп
http://www.cqham.ru/forum/showthread...=1#post1549611
http://www.cqham.ru/forum/showthread...=1#post1549650
для работы в схеме регенератора с "батарейным" питанием. Под батарейным напряжением понимается 12,6 В напряжение аккумулятора из двух банок по 6,3 В. Оставшиеся 6 ламп 6Ж1П проверил при напряжении анодной цепи 21 В - 26 В. В результате 4-ре лампы заработали в схеме регенератора (индуктивная трёхточка) но со смещением 0,1 В или выше на первую сетку. Две лампы не заработали. Попробовал для схемы регенератора лампы 6Ж52П. Одна из ламп заработала при анодном +26 В и смещении 0,1 В на первой сетке. В общем приобретение Б/У ламп на рынке для работы с низким анодным напряжением лотерея, повезёт или не повезёт.
я тоже не понимаю смысла использовать низкое анодное напряжение. Зачем?:roll:
Время, потраченное на изыскания "будет-не будет работать" лампа при низком анодном :killyourself: лучше использовать на создание приличного лампового БП на паспортные значения анодного напряжения.8-)
Когда то задавался вопрос - были ли промышленные образцы приборов с низким анодным. Есть ИРК-2 - Испытатель радиокомпасов, питается от бортсети авиатахники 27 В +- 10%. В нем ДВ - СВ ВЧ генератор с модулятором на двух пальчиковых лампах, умформера нет, анодное - 27 В. Прибор имеется, ТО нет, доберусь - посмотрю, какие лампы.
Кроме просто любопытства при каком анодном напряжении может работать лампа в схеме регенератора для этого специально не предназначенная, есть желание запитать схему от USB порта ноутбука. Это 5 В без каких либо преобразователей.
Такой лампы нет, на радиорынке лампы этой серии были такие ржавые что покупать не стал. При случае и наличии рабочей лампы проверю. Пока результаты такие: напряжение накала 5 В (напряжение в случае питания от USB) некоторые лампы 6Н1П работаю при анодном 10-12 В и нувисторы 6С52Н. Лампа 6Н23П работает от 0,5 В анодного и накальном 5 В. Нравится лампа 6Ж1П из-за "меньшего" тока накала (0,17 А) в сравнении с 6Н23П. Но не могу заставить работать этот экземпляр при 5 В анодного. Работает при 5,8 В анодного и положительном смещении на первую сетку. Накал 5 В.
Вложение 293448
