Тогда либо KENWOOD врет, либо кто-то не можно найти разница в произношение букв A и I !!!! :lol: :oops:Цитата:
Сообщение от UN7CI
http://www.youtube.com/user/Aseecobra
http://www.youtube.com/user/Aseecobr.../0/UtGpj7g9cD0
Сообщение от UN7CI
Ну а самый главный вопрос вы уточняли? Преобразование вверх или вниз? И рабочая частота руфингов первой ПЧ?Цитата:
Сообщение от isartw
came from Dayton. Here is what Phil Parton, Sales Manager from Kenwood USA
said about the 590:
1. Down conversion receiver (11 Mhz 1st IF) with a 2.8kHz & 500 hz filters.
Wider bandwidths will have the filters switched out.
2. 12VDC input with a 100w PA and tuner.
3. Toshio Torii, Engineering Manager of Kenwood JP used the K3 as inspiration
for the receiver performance.
4. Specs are not finalized and they are still listening to any input from
customers. Send Kenwood your thoughts.
5. Some planned features were not present in the demo radio.
6. October 2010 is the hopeful sale date.
7. $1800 price.
Here is what I saw:
1. RX antenna & transverter connections on rear.
2. USB connection on rear seems have audio capability.
3. Hard and soft processor settings.
4. AGC adjustable.
5. 3kHz max TX bandpass and 5kHz max receive bandpass. Fixed EQ shaping.
6. Auto & manual notch.
And some other possible features or changes that are not official at this time:
1. Parametric TX EQ & noise gate.
2. Hard and soft RX filter skirts.
3. Interfacing two 590s together for TX/RX.
4. Buffered IF output for pan display.
And for the future:
1. Top line radio within two years with $5k price. Maybe TS-990.
2. TS-2000 has a planned overhaul. No confirmed time frame.
I posted some pictures and will post my videos later. Or look at the Youtube
video Roar posted the link too from another ham.
Преобразование вниз, частоту не уточнял. Один руфинг на SSB, другой на CW, полосу не помню.Цитата:
Сообщение от UU2JJ
Слав спасибо! Я в курсе, что первая ПЧ в КВ тракте 11,450MHz и стоят полноценные кварцевые фильтры. А на 50MHz - со слов очевидцев преобразование вверх... Но вопрос я задал умышленно, что-бы кое кто, с выводами о марганцовке, все-таки не спешил, и IF с AF не путал! :rotate:Цитата:
Сообщение от Slav
Я спросил буквально следующее - Are you sure this rig equipped with audio frequency DSP ? I am surprised a little bit...Цитата:
Сообщение от UU2JJ
на что чел ответил: That's right, this one comes with 32-bit audio frequency DSP but this cannot be compared with DSP in 570th. This one is quite different and more advanced. But this is AF DSP ...
Так что, я ничего не путаю. Другое дело, я особо в подробности не вдавался. Просто тот же самый вопрос мимоходом задал другой чел когда я крутил ручки и я насторожился и решил перепроверить, потому как сам не ожидал. Для меня AF DSP в 570-м была одной из причин, по которой я этот аппарат сбыл в свое время.
Нужно ждать буклет, а так гадание на кофейной гуще.
Преположим, что на постере ошибка.
Предположим, что с одним преобразованием и ДСП по НЧ. Что совсем неплохо.
Жаль... Я то надеялся на IF-DSP... Хотя подождем с официальным анонсом продаж...Цитата:
Сообщение от isartw
На стенде в Дэйтоне по срокам сказали буквально следующее:Цитата:
Сообщение от RK4FB
Начало производства в августе этого года. Начало продаж - в сентябре. В общем ждать не так уж и долго.
73!
Виктор
Володя ты прав, че гадать в пустую, скоро купим и все узнаем! :)Цитата:
Сообщение от ES4RZ
Хотя я думаю, и те и другие, утверждения правильны и ошибки нет.
Просто по аналогии с TS-870S и TS-2000:
Стоит один чип DSP по IF с фильтрами, NR и Notch,
и второй чип DSP по AF, с функциями EQ-RX/TX и BC...
(Не забывайте что главный разработчик тот-же самый, да и дорожка проторенная! :super: )
