Воот , интересно кто то уже сделал?
AC8DP 20 апреля сообщил что ждет запчастей, и кто то уже сделал (некто YO) уже сделал,но подробным мануалом делится не хочет :(.
В ветке не получилось спросить результат,написал ему в личку.На QRZ майла нет,только почтовый адрес.А вообще идея интересная.
RU6AI, Спасибо!!!
Можно подумать , что F71022 Z везде , как "блох на собаке" ! Это тоже еще тот дефицит , идея заменить ею М6311 витала в воздухе еще в конце прошлого века .
То же верно :). Сначала найти нужно то ,чем менять..
TS-450s DDS replacement for YM6631 Since I still own a TS-450s and I think they're fabulous.. I thought this might be of interest.A replacement solution for the faulty DDS chips has been found by a fellow ham from YO. The replacement parts are available from Kenwood. Since he's unwilling to produce detailed instructions/pictures etc, heres what I found out in short (use this info at your own risk):The YM6631 / YM66312 chips can be replaced with the newer and less prone to failure F71022z used in the TS-950. They are functionally equivalent except:-the F10722z is in a TQFP44 package.-the F10722z has a 12 bit output.-there's apparently no provision for direct frequency modulation (fsk) but "who needs that anyway".So if you think it's worth it, and you're proficient in SMD and DDS, this is what you have to do:-order the parts from Kenwood. They are rather expensive - about $40 a piece.-Get a couple of TQFP prototype boards. Install the new chips on the prototype boards.-Wire the AVDD pins together, the DVDD's, the VSS's. Install decoupling capacitors. -Remove the old chips from the Kenwood board. Clean the pads. Solder thin, insulated wires to the pads to help you attach the prototype boards.-solder in the prototype boards in place of the old chips. Use the TS-450 schematic and the TS-950 (or even better TK-80) to see what needs to be connected where. Pin 1 of the F10722 should be "lower right" as you face the radio's front panel with the board in its original position, this I'm told allows for straightforward connections. It should be "pretty obvious what goes where" I'm told, with the exception of digital outputs where you have to:-Skip pins 38, 40 and 41 on the original Kenwood board. Connect the next dig. output to pin 37.-On one of the 2 R2R output networks for each chip, where the missing digital outputs would have been connected, short pin 16 to pin 13. Note that the YM6631 uses only 15 out of 16 existing digital outputs and the newer chip has only 12.-Unused or grounded pins = use the TK-80 schematic to figure it out.-Accuracy, static protection, short connections, grounds = dead rig to working rig. That's all I know, good luck.Замена в TS-450 DDS-чипа YM6631 Я до сих пор использую TS-450, это настоящая легенда. Полагаю, что то, что я скажу, будет для многих интересным. При выходе из строя DDS чипа возможно решение, которое нашел один из радиолюбителей в Румынии. Детали для замены можно приобрести у Kenwооd. Поскольку румын не хочет раскрывать деталей, делиться какими-то данными по замене, вот что я могу сказать по этому поводу вкратце (используйте эту информацию на свой страх и риск!).YM6631 / YM66312 могут быть заменены более новыми и менее подверженными выходу из строя чипами F71022z, используемыми в TS-950. В функционально отношении они почти эквивалентны, но есть различия:- F10722z в корпусе TQFP44;- у F10722z 12-битовая размерность выходного сигнала;- не предусмотрен режим прямой модуляции частоты (fsk), но допускаю, что многим это «по фигу».Таким образом, если вы полагаете, что заморачиваться есть смысл и вас не пугает все, что связано с DDS, SMD-монтажом, следует, вероятно, сделать следующее:- заказать микросхему в Kenwood, однако надо знать, что она дороговата – 40 долларов за корпус;- заказать для монтажа TQFP-переходную панель;- распаять выводы соответствующие маркировке AVDD, DVDD, VSS, распаять развязывающие емкости;- удалить старую микросхему, почистить плату, припаять тонкие изолированные провода для того, чтобы присоединить ими новую схему; - заменит старую схему, внимательно разведя проводники; при разводке используйте схемы TS-450 и TS-950 ( еще лучше - TK-80); вывод 1 F10722 должен быть «справа внизу», если смотреть со стороны лицевой панели; необходимо очень внимательно разобраться в том, что с чем должно быть соединено; кроме всех выводов цифровых сигналов надо сделать следующее:- пропустить выводы 38, 40, 41 плате Kenwood, следующий цифровой вывод соединить с «ногой» 37;- соединить выводы 13 - 16 для обеих микросхем для двух R2R выходов: помните, что YM6631 использует только 15 из 16 имеющихся выходов, а новая схема имеет их всего 12;- для неиспользуемых и заземленных выводов – смотрите их соединения на схеме ТК-80;- внимательность и аккуратность, защита от статики, короткие соединения, необходимые заземления и – чудо – мертвое радио становится живым радио.Вот и все, что я знаю, успехов!К сожалению, ряд формулировок у автора не очень четкие, что часто бывает и в наших российских текстах на сайте. Поэтому, полагаю, материал надо использовать осторожно, необходимо будет связаться с его автором, в оригинале позывной указан. 40 зеленых - это денежка заметная... 73!
AC8DP дал ответ
Works 100% like before
Keep wires short (use flexible, thin and well insulated wire)
Remember you have 12 bit DAC not 16, you will have to short 4 pins on the resistor network
Интересно более внятное решение с Y66312 не появилось на "сегодня"? P.S предлагают такой аппарат но из за этой микросхемы боязнь покупать его.:-(
