Standard PROFIBUS DP Fast Connect cable for stationary applications and specially designed for fast assembly. This cable complies exactly with the PROFIBUS DP cable specifications (200 m at 1,5 Mbps or 100 m at 12 Mbps). Due to its double shielding and acceptable shield resistance it is suitable for installation in EMC demanding areas.
Technical specifications
Electrical characteristics
Impedance: 150 ± 15 Ohm
Loop resistance: < 110 Ohm/km
Shield resistance: < 10 Ohm/km
Capacitance: < 28,5 nF/km
Inductance: 1000 uH/km
Attenuation: 42 dB/km (16 MHz)
Mechanical characteristics
Construction: 1 x 2 x 0,64 mm (22 AWG)
Wire type: Solid conductor
Cable thickness: 8,0 mm
Weight: 76 kg/km
Sheath and wire colors: Violet and red/green
Fast Connect (FC): Yes
Имхо, хуже витой пары даже, затухание слишком высокое.
