1. OSCAR - 07
Linear transponder downlink 145.950 MHz,
Linear transponder uplink 432.125 MHz
рабочий
2.CAS-4A
Linear transponder downlink 145.870 MHz,
Linear transponder uplink 435.220 MHz
emission designator 20K0V8WWF, output power 20 dBm
CW telemetry beacon 145.855 MHz, emission designator 100HA1AAN, output power 17 dBm
GMSK telemetry 145.835 MHz, emission designator 16K0F1DCN, output power 20 dBm
не рабочий
3.CAS - 4B
Linear transponder downlink 145.925 MHz
Linear transponder uplink 435.280 MHz
CW telemetry beacon 145.910 MHz, emission designator 100HA1AAN, output power 17 dBm
GMSK telemetry 145.890 MHz, emission designator 16K0F1DCN, output power 20 dBm
не рабочий
4.JO-97 ( JY!Sat )
Downlink 145.855-145.875 MHz (USB)
Uplink 435.100-435.120 MHz. (LSB)
The telemetry downlink frequency is 145.840 MHz, this will use the usual FUNcube standard 1k2 BPSK format. The linear transponder, for Single Sideband (SSB) and CW
рабочий
5.TO-108 (CAS-6)
U/V Linear Transponder Downlink: 145.925 MHz
U/V Linear Transponder Uplink: 435.280 MHz
CW Telemetry Beacon: 145.910 MHz 17dBm
AX.25 4.8k Baud GMSK Telemetry: 145.890 MHz 20dBm
CAS-6 will be launched to a sun-synchronous orbit at 629 km with an inclination of 97.89 degrees. The satellite carries a 20 kHz wide.
рабочий
6.XW-2B CAS-3b
- uplink: 435.090 to 435.110 LSB
- downlink: 145.730 to 145.750 USB
- CW Beacon 145.725
- TLM Beacon 145.705
не рабочий
7. XW - 2C CAS-3c
- uplink: 435.150 - 435.170
- downlink: 145.795 - 145.815
- CW Beacon: 145.790
- TLM Beacon 145.770
не рабочий
8.AO-73 (FUNcube-1)
- uplink: 435.130 to 435.150 LSB (435.140 MHz) ставим в орбитроне
- downlink: 145.950 to 146.970 USB (145.960 MHz) ставим в орбитроне
рабочий
прямая ссылка на лог AO-73 _ http://aar29.free.fr/sat/ao73/logentry.php
- CW beacon: 145.935
- digital telemetry: 145.935
Download FUNcube Telemetry Dashboard software
LUSEX (LO-87 / NUSat-1)
uplink of 435.935 MHz to 435.965 MHz
downlink of 145.935 MHz to 145.965 MHz
Total power output is 250 mW.
CW beacon at 145.900 MHz with a power output of 70 mW.
EO-88 (FunCube on Nayif-1)
435.045-435.015 MHz Uplink
145.960-145.990 MHz Downlink
• 145.940 MHz 1200 bps BPSK FUNcube beacon
• 500 mW inverting SSB/CW linear transponder
UVSQ-SAT
LATMOS-01
Uplink: 437.020 МГц
Downlink: 145.905 МГц
Telem. 437.020 МГц - G3RUH 9k6
Для декодирования сообщений,вы можете использовать программное обеспечение декодера UVSQ-SAT, доступное по адресу: https://code.electrolab.fr/xtof/josa.../UserManual.md
Beacon baud rate: 1200 bps and 9600 bps
Beacon interval: 30 seconds
Bandwidth: 20 kHz
Modulatieon typ: BPSK
Protocol: AX-25 framing
Encoding: NRZI encoding and G3RUH scrambling
