1 5 1234 ...
1 10 44
    30.11.2021
    50
    , , 2000 . ? .
      cuneum
    28.12.2015
    2,282
    koks1960
    "rotary.h", 1. , .
    #define ENCODER_A 2 // Encoder pin A
    #define ENCODER_B 3 // Encoder pin B
    boolean encA = 1;
    boolean encB = 1;
    boolean encA_sav = 1;
    boolean encB_sav = 1;
    short incr;
    void setup ()
    pinMode(ENCODER_A, INPUT_PULLUP);
    pinMode(ENCODER_B, INPUT_PULLUP);
    boolean encoder()
    encA = digitalRead(ENCODER_A);
    encB = digitalRead(ENCODER_B);
    if ((!encA & encA_sav) or (!encB & encB_sav))
    if (encA > encB){
    incr = -1;
    return 1; //
    else if (encA < encB){
    incr = 1;
    return 1; // , 11/22
    encA_sav = encA;
    encB_sav = encB;
    return 1;
    encA_sav = encA;
    encB_sav = encB;
    return 0;
    30.11.2021
    50
    cuneum
    . 328, . 328 :collect2.exe: error: ld returned 1 exit status. , . ?
    16.11.2009
    1,328
    koks1960, PB, ?
:	1.png
:	158
:	19.1
      cuneum
    28.12.2015
    2,282
    R9OFG
    PB, ?
    , Arduino IDE, , , -, .
    12.09.2006
    , , KN34PC
    2,190
    LZ2WSG
    SI47XX MCUdude/MiniCore ATmega328PB.
    , Arduino, . 5 .
:	lib_hdw.jpg
:	98
:	135.3
:	si47xx.jpg
:	90
:	616.6
    30.11.2021
    50
    veso74
    . 5 .
    328, 328, . MCUdude/MiniCore. R9OFG , , .
    12.09.2006
    , , KN34PC
    2,190
    LZ2WSG
    . 328PB: exit status 1 :/.
    arduino-ide_2.1.0 : Compilation error: exit status 1
    veso74; 22.01.2024 15:02.
    20.11.2007
    703
    RA3PPV
    328p pb ?
    30.11.2021
    50
    Kim_Dim
    328p pb ?
    IDE 2.2.1 1.8.19
    C:\Users\12\AppData\ Local\Temp\arduino_b uild_240096/SI47XX_03_TFT_ATMEGA 328_ST7735.ino.elf section `.text'' will not fit in region `text'
    c:/users/12/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld.exe: region `text' overflowed by 950 bytes
: 1 (: 0 , : 1)
  1. : 32
    : 05.02.2021, 23:50
  2. 144/435
    us4lf
    : 39
    : 08.09.2017, 19:13
  3. DDS
    gudzon-m
    : 35
    : 08.08.2016, 21:13
  4. catmasik
    : 51
    : 10.03.2015, 10:17
  5. -
    tetan
    : 61
    : 20.02.2012, 20:18
