Страница 24 из 24 ПерваяПервая ... 1421222324
Показано с 231 по 235 из 235
Тема: Владивосток, APRS, Winlink, шхуна "Чава"
  1. #231
    Модератор Аватар для DL8RCB
    94157 Perlesreut
    13,063
    DL8RCB, ex UW9EZ
    так уж совпало, но сегодня 12 апреля Игорь отработал "с колес" автомобиля WINLINK Pactor,до этого мы работали пактором только их стационара
    Последний раз редактировалось DL8RCB; 12.04.2016 в 19:16.
  2. #232
    94157 Perlesreut
    13,063
    DL8RCB, ex UW9EZ
    On April 15, 2016, the Winlink system will begin requiring the use of passwords and secure login for ALL users. This is being done to enhance the privacy and protection of the Winlink community. If you've already entered both a password and also turned on Secure Login, you don't have to make any other changes. The transition taking place on April 15, 2016, won't change your operation. If you have not set a password for your account, and also have not enabled Secure Login, we recommend you do it now so you won't be surprised on April 15, 2016.
    FOR RMS EXPRESS, setting a password and Secure login are very easy to do:
    1. Connect your computer to the Internet.
    2. Run RMS Express.
    3. Click the menu item ?Files" then "RMS Express Setup"
    4. Enter your password in the field next to your callsign, and insure that the "Require password on connections (Enable Secure Login)? is checked.
    4. Enter a password recovery e-mail in the appropriate field. This must be a non-Winlink address.
    5. Click "Update".
    6. RMS Express will set your password on the Winlink system and enable secure login.
    NOTE: If you're using a different Winlink e-mail client program such as Paclink or Airmail, you must follow these steps:
    1. Go to www.winlink.org, and select the MY ACCOUNT tab.
    2. If you haven't previously selected a password, select one now. Otherwise log in.
    3. Navigate to the screen that lists your account information, and click EDIT.
    4. Scroll down and enter your password-recovery e-mail.
    5. Check the box to enable Secure Login.
    6. Click SAVE at the bottom of the screen.
    7. Next, find the place in your Winlink client program where you can enter your password, and set it for the client.
    8: NOTE: FOR AIRMAIL: If you have gone to menu item, TOOLS>OPTIONS>SETTIN GS, put in your password, and saved it, you will be okay. If you have no password for Winlink, follow the instructions above.
    Your Winlink Development Team
  3. #233
    94157 Perlesreut
    13,063
    DL8RCB, ex UW9EZ
    сегодня получил подтверждение от нового корреспондента из девятого района R9XU, принимал и отправлял пактором через SM4RVH via 30 m (антенна auto-мобил вариант)
  4. #234
    94157 Perlesreut
    13,063
    DL8RCB, ex UW9EZ
    добавил еще одну "базу" на 438 225 Мгц
  5. #235
    КВ вертикал на стальной парусной шхуне - ссылка на тему в разделе "КВ антенны"
    И чтоб два раза не вставать - RMS RK0LXA временно выведена из эксплуатации. У дома начали капитальный ремонт крыши, пришлось на это время убрать антенну.
    Антенна использовалась Hustler btv6, была установлена летом 10 года, по требованию жилконторы без каких-либо креплений и изменений кровли. Был сделан накладной фундамент из фанеры, который был уложен на конек через нескользяшку из автомагазина. Он был раскреплен по углам растяжками, противовесы и антенна растянуты леской 2 мм. Как ни странно, леска за 9 лет не потеряла прочности и антенна успешно отработала все это время без обслуживания. Правда, это настоящая морская леска.
    Если твоя бумага разлинована, пиши поперек.
  6. Спасибо от DL8RCB
  1. "наши" полосовые диапазонные фильтры от "РЭМО
    от RU0LL в разделе Продавцы, покупатели...
    Ответов: 165
    Последнее сообщение: 19.09.2019, 14:34
  2. Энергосберегающие лампы. "ЗА" и "ПРОТИВ"
    Ответов: 1688
    Последнее сообщение: 11.10.2018, 18:46
  3. APRS от "А" до "Я" - Комментарии
    от RX1AL в разделе Программное обеспечение
    Ответов: 211
    Последнее сообщение: 16.04.2013, 14:09
  4. Кнопки "UP","DOWN" тангенты HM-36 ICOM-7
    от RW6AUR в разделе Технический кабинет
    Последнее сообщение: 10.07.2012, 19:33
  5. "Емкостное реле" журн. " Радио" 2010/5 (датчик приближения человека)
    Ответов: 48
