035 GENE FRQ ADJ повлияет и на прием и на передачу (причем только на показания частоты)
065 A3J LSB CAR 066 и A3J USB CAR относится к приемнику
Спасибо Андрей все практически и понятно....
de ua3lbb:По поводу не отключения FT-950 от кнопки- ключи Q5401 и Q5402 не причем.После
нескольких отключений от БП трансивер стал отключаться от кнопки, не знаю надолго ли.
Алексей UA3LBB
Информация к размышлению.
Цитата из отзыва VE2EZD на http://www.eham.net/reviews/detail/8031
"... The FT-950 is an amazing radio except for one complaint, the audio stage hiss and you'll be surprised to know that it can be fixed EASILY.
To make a long story short, Yaesu messed up in the gain distribution in the different parts in the audio stage. The final amplifier is built around the excellent Sanyo LA4425A. This chip forms as Sanyo says a "minimal component high quality amplifier", so Yeasu couldn't have messed there. The problem had to be before this amplifier. This amplifier is always working at full amplification and audio gain control is applied to the preceding stages. To feed the LA4425A with the right audio level there is an attenuator at its input wich is a voltage divider. I found that the attenuation at this point is insufficient. This lower than adequate attenuation forces the preceding audio stages to work at a level so low that they are near their own noise levels. This noise is then amplified by the LA4225A and that's the hiss you ear in the headphones.
The solution is very simple: rise the attenuation by lowering the value of one resistor of the voltage divider that make the attenuator. The preceding audio stages will now have to work at a more confortable level higher than their own noise level.
The attenuator is composed of two resistors: R1414 (22 k-Ohms) and R1419 (3.3 k-Ohms and the one that goes to ground). I did install a 2.2K-Ohms shunting resistor parallel to R1419 to lower its value. I reassembled the radio and connecter my Sony headphones to it. What a difference! I was literraly blown away. Signals were now so clear in my ears like never before.
The receiver is now super quiet. Also, the resistors of this voltage divider work with C1601 to form a low pass filter. According to F1BOH this low pass filter has its cut-off frequency right in the middle of the audio passband. By lowering R1419 you rise the low-pass filter's cutt-off frequency out of the audio passband. You end up with more gain in the higher frequencies where the radio was lacking.
Are there drawbacks to this mod? Not at all! It seems that this radio was meant to work like this. There is so much audio amplification in this radio that the volume control still work as you would expect from a great rig.
Gone now the hiss I heard at low adio level and to top that you gain audio definition in the higher frequencies..."
Последний раз редактировалось K2KSB; 11.09.2011 в 07:29.
не могли бы вы с "тарабарского" кореректно перевести эту статью? хотябы жирно выделенную часть.
трансляте сайт выдаёт вот такой текст, смысл примерно понятен, но.....
ФУТЫ 950 являются удивительным радио за исключением одной жалобы, аудио шипения стадии, и Вы будете удивлены знать, что это может быть установлено ЛЕГКО.
Короче говоря Yaesu испорчен в распределении выгоды в различных частях на аудио стадии. Заключительный усилитель построен вокруг превосходного Sanyo LA4425A. Эти формы чипа как Sanyo говорят "минимальный составляющий высококачественный усилитель", таким образом, Yeasu, возможно, не замарал там. Проблема должна была быть перед этим усилителем. Этот усилитель всегда работает при полном увеличении, и аудио получают контроль, применен к предыдущим стадиям. Чтобы накормить LA4425A правильным аудио уровнем есть аттенюатор в его входе wich, сепаратор напряжения. Я нашел, что ослабление в этом пункте недостаточно. Это понижается, чем соответствующее ослабление вынуждает предыдущие аудио стадии работать на уровне настолько низко, что они около их собственного уровня шума. Этот шум тогда усилен LA4225A, и это - шипение Вы ухо в наушниках.
Решение очень просто: поднимитесь ослабление, понижая ценность одного резистора сепаратора напряжения, которые делают аттенюатор. Предыдущие аудио стадии должны будут теперь работать на большем confortable уровне выше чем их собственный уровень шума.
Аттенюатор составлен из двух резисторов: R1414 (омы на 22 k) и R1419 (омы на 3.3 k и тот, который затаился). Я действительно устанавливал 2.2K-омы, шунтирующие резистор, параллельный R1419, чтобы понизить его ценность. Я повторно собирал радио и соединитель мои наушники Sony к этому. Какое различие! Я был сдувшим literraly. Сигналы не были теперь настолько ясны в моих ушах как никогда прежде.
Приемник теперь супер тихий. Кроме того, резисторы этого сепаратора напряжения работают с C1601, чтобы сформировать фильтр нижних частот. Согласно F1BOH у этого фильтра нижних частот есть своя частота среза прямо в середине аудио полосы пропускания. Понижая R1419 Вы поднимаетесь фильтр нижних частот cutt-прочь частота из аудио полосы пропускания. Вы заканчиваете с большим количеством выгоды более высоких частотах, где радио недоставало.
Там недостатки этому моднику? Нисколько! Кажется, что это радио предназначалось, чтобы работать как это. Есть такое большое аудио увеличение в этом радио, что регулировка громкости все еще работает, как Вы ожидали бы от большой буровой установки.
Уведенный теперь шипение я услышал на низком adio уровне, и превысить это Вы получаете аудио определение в более высоких частотах..."
речь думаю об этом
