для меня загадка однако?
перенесемся сюда
http://www.cqham.ru/forum/showthread.php?t=20210
чтобы не флудить
(потом ветку почищу)
73
Программа постепенно обновляется вводятся новые возможности, пробуем дальше
О замеченых недостатках и пожеланиях пишите автору, он все учитывает в дальнейших версиях
Version 0.9.511 Beta
17 November 2012
- Added Weather Station option. SARTrack can now be used as a Weather Station, based on a standard Weather File which must be generated by the software which comes with the Weather Station hardware. (Setup/This-Station)
- Added user selectable Track Width for all Tracks on the screen (Setup/Maps)
- Added option to use UTM coordinates at various places in the program. To use UTM instead of NZTM or WGS84, change the Default Setttings in Setup/General.
- Added option to enter coordinates in the SAR Log, which can be transmitted as an Object. This function currently only works in UTM, other systems will ba added next update.
- Added Tracks to Overlays. Previousely, a moving Overlay did not have a track.
- CHANGED TNC INIT COMMANDS. The TNC Commands must now have the end-of-line characters in the TNC Commands itself. They are no longer added internally by the program. This means you must change your TNC settings to include ^M^J at the end of all commands. Some TNC's need this the other way around.A New tncs.txt file can be downloaded from the sartrack website.
- Added TNC Terminal (Start from Setup/TNC). This will enable you to test your TNC. Note: This is not quite finished yet.
