Показано с 1 по 10 из 11
Тема: Как раскрыть IC-736 на передачу?
    Буду очень благодарен, кто подскажет как
    открыть на передачу IC-736. Слышал надо
    выкусить D15, а дальше каке действия?
    ux7mx
    Privet u menya est Icom 737
    Alex. спасибо за инфо. С рождеством!
    k2pal de ux7mx 73!
    Иван! На здоровье!
    Спасибо. И вас тоже с рождеством и новым годом!
    ДХ ов ,Здоровья и успехов!
    73!
    Да вот по икому 736
    Icom IC-736 (IC 736 IC736) Speed-up the ALC
    I got a IC 736 in December 1994. It is a good rig but had also a lot of misstate. After a time of measuring and testing I found the ALC for transmitting is to slow. So I jacked the circuit why is so. I found a C-R delay in the way from the ALC on the Main Unit. It is the C287(1uF) and the R305(150Ohm). The C change or put out is not very easy. So I change the Resistor 305 in to smaller one. But the result was not better. The best result I had without it! So the C-R combination is not in the work for the ALC. The Resistor 305 is very small but it is easy to put out. On the Resistor is the number 151 printed (150Ohm) but you mast find it on the circuit.
    To be wide TX you mast only cut the Diode D15 on the Logic Unit.
    The IC 736 works very well at the last half year so I send it out in the PR-news now.
    ъъъъъъъъъъъъъъъъъъъъ ъъъъъъъъъъъъъъъъъъъъ ъъъъъъъъъъъъ
    Icom IC-736 (IC 736 IC736) Mar/Cap Mod
    1. Remove power, antennas etc.
    2. Turn rig upside down with front of rig facing away from you, remove bottom cover
    3. Looking at the back side of the front panel "logic board" just to the side of center, along the bottom (actually now at the top) you'll see diode D15, this is a typical non-surface mount glass diode.
    4. Clip this diode.
    5. Reassemble rig.
    Mod complete.
    Not responcible for errors on your part.
    ьььььььььььььььььььь ьььььььььььььььььььь ььььььььььььььььььь
    Icom IC-736 (IC 736 IC736) DDS/VCO Bug/Fix
    I have just received confirmation from ICOM Canada that there is a bug in the design of the IC-736 with respect to frequency generation. It seems that although it seems to be a common problem, not all IC-736's exhibit the problem. It seems that there is a "floating" data/address line and at times it floats the wrong direction, giving about 30HZ (maybe 32HZ?) difference in LSB mode. The fix is to solder a 47K resistor between pins 17 and 10 on IC24 on the main board. (bottom of radio, near front). I have not yet tried the fix, as I just got it today.
    To see if you too have the problem, try the following test:
    1. switch to AM first and tune to a strong AM carrier, and switch to LSB (once and only once) 40M is a good place to try this.
    2. tune the carrier to about 400HZ tone and listen carefully.
    3. switch to USB and back to LSB quickly. You should hear a different tone. If not, then you are "floating" in the right direction.
    4. switching to USB and back to LSB will not produce any more differences. You must LEAVE SSB mode (ie AM) and come back to LSB for the first time to re-set the "floating" line. It is the LSB/USB/LSB switch that shows the difference in the two LSB received frequencies (by tone only, the display does not change...)
    I've tried to post this message about 4 times so far with no apparent success.
    Иван!!
    я уже давал тебе инфо!Правильно сделать надо так ICOM IC-736
    EXPD RF 1.6 - 33.0 Mhz & 45 - 60 Mhz
    1- Remove power and antenna.
    2- Remove screws and remove cover
    3- Locate logic board (front of radio).
    4- Locate and CUT D-15 (near connector).
    Diode D-14 is the expanded RX diode make sure it is removed.
    5- Reassemble the radio.
    6- Reset the microprocessor if required
    73!
    Спасибо Алекс, и все таки D15 надо
    удалить. А вот что дальше, никаких
    корректировок не надо делать?
    Боюсь чтобы не наломать дров.
    Там говорится если нужно то Восстановите микропроцессор,
    Reset the microprocessor if required !
    Ну,а если случится,что не так, они об этом предупреждают!
    Но я думаю все должно быть ок!
    Иван успехов и 73!
    Алех
    Спасибо за инфо Alex, поищу еще, может найду кого нибудь из наших, кто
    проделал эту процедуру. С Новым годом, счастья, здоровья и удачи. 73!
    ux7mx
    Привет Иван!
    Инфо сдесь http://www.sp5pbe.waw.pl/~zygi/RigMo...36/ic-736.html
    И сдесь инфо
    Q: My IC-736 or IC-738 HF base radio is about 800 Hz - 900 Hz off frequency.
    A. Reset the CPU (Hold [CLR] & [ENT] buttons and turn the radio on).
    73! Alex
    Алекс, спасибо. Я думаю информации
    предостаточно. Буду заниматься.
    Потом сообщу результаты. Пока, 73!
    ux7mx
  1. IC756 раскрыть на передачу
    от R6BK в разделе IC-756
    Последнее сообщение: 25.05.2020, 18:34
  2. Как раскрыть на передачу FT-950
    от Alexander_Gorlovka в разделе FT-950
    Последнее сообщение: 13.01.2010, 20:22
  3. KENWOOD TS-930sat раскрыть на передачу
    от er2oz в разделе Технический кабинет
    Последнее сообщение: 16.10.2009, 22:36
  4. Раскрыть FT-1000MP на передачу
    от UR8IN в разделе FT-1000
    Последнее сообщение: 02.11.2008, 16:07
  5. Ответов: 3
    Последнее сообщение: 05.09.2006, 22:38
