ну в будущем может и быть, хотя маловероятно, не те объемы производства, чтобы возить за тридевятьземель. Переключатель в П-контуре китайцы до сих пор не делают, приходится в штатах покупать по 350 долл :(
Только что получил мыло от Rudi Breznik, VK2AOT, из этого самого "EMTRON HF LINEAR AMPLIFIERS" в котором он с телячьей радостью описывает полный отказ от ГУ-серии и полном переходе на FU-лампы (англицкая аббревиатура наводит на нерадостные размышления...):
"...FU-728B tube! This tube is the Chinese military version of the popular Eimac 4CX-1500B. The only difference is the filament voltage (9volt) and the center pin on the tube socket, which is about 1mm thicker. This tube is also 14mm higher and therefore better and more efficient cooling. The tube is still manufactured in China, readily available from Greenstone USA or sources in China. All Emtron amplifiers are using now these tubes with a modified socket, in order to accommodate the FU-728F as well as the Eimac 4CX-1500B tubes!! To change from one tube to the other, only filament tap on the transformer must be changed.
The reason that we changed to these tubes is twofold. The tubes are still being manufactured, and they are cheaper and more economical. If we want to manufacture amplifiers, we must plan ahead into the future, we must know, from where our vital components will come from!
The Russian GU-78 tube is extremely hard to get, and it cost over US$700 today. This is why some six years ago we changed from GU-78 to GU-84. Now the GU-84 as also expensive and hard to get, since these tubes are no longer manufactured. The Chinese tubes are still being made and they are excellent performers. We are extremely happy with them. More then ten years ago, we introduced the Russian tubes to the commercial amplifier market, and everybody followed! Remember, in one year time, everybody will be using Chinese tubes. Alpha in USA is already using the Chinese 4CX1000A in their amplifiers.
For any more info, please don't hesitate to ask!
Please note, to show our customer support, we have introduced a new replaceable tube module, whish can be directly replaced in any old model Emtron amplifier using Russian tubes (specially the 4CX-1600B, GU-84B and GU78B) with the new Chinese tubes!!! This is the big advantage of "Modular Construction" of all Emtron amplifiers! No other manufacturer in the world does this! EMTRON AMPLIFIERS NEVER GET OLD!!"
А вопрос у меня такой, кто либо видел ТТХ на эти (FU-728F) лампы, не Eimac 4CX-1500B, а действительно китайские данные?
Cathode:Oxide-coated unipotential
Heater : 8.5-9A @9V
Cathode warm up time: 3min (Min)
Interelectrode Capacitances( grounded cathode connection):
Input: 103 pF
Output: 13.3pF
Feedback: 0.03pF
Transconductance: >=14.3mA/V
Maximum operating temperature:
Ceramic/metal seals: 250°C
Anode core: 250°C
Cooling Forced air
Air-flow requirements: 3000l/min
Net weight: 950g
Class AB1 radio frequency SSB linear amplifier(below 110MHz):
Ua=3000v
Ug2=350V
Ug1=-79V(zero-signal plate current Ia=250mA)
Plate dissipation: 1200w
Pg2 dissipation :12W,
Pg1 dissipation :0W
Ia=0.9A
Output power:
110MHz Class AB1 Linear amplifier
Single-tone: 1800w
Two-tone: 2500w
Thanks a lot. In other words its Gu-43B in a different package.
Прилагаю копию мануала только что полученную от Эмтрона, она ни кому ни чего не напоминает? (вопрос риторический), да и вопросы о применении компутерных разъемов уважающими себя производителями, поднятый где то ранее, тоже вроде утрачивают актуальность... да и насчет переключателя диапазонов не надо на китайцев кидаться, если бы в оригинале стояло что то приличное, то и они бы передрали должное качество... не в тот огород камешки полетели. Емтрон обиделся на заданные вопросы и отвечать отказывается. Расхотелось ему уже продавать свой усилитель... (покрайней мере мне...)
Последний раз редактировалось olegtf; 05.02.2012 в 14:44.
Дайте ссылку где это чудо китайское продают?
Ответ от BG7JAA:
You can find US5WDX buy.
Усилители 1200,2000,4000 ватт из Китая давно в России и по нормальной цене
http://www.amptec.ru
