Страница 664 из 1117 ПерваяПервая ... 164564614654661662663664665666667674714764 ... ПоследняяПоследняя
Показано с 6,631 по 6,640 из 11165
Тема: ГИ-7б и другие металлокерамические триоды
  1. #6631
    Ростов Великий
    173
    and Selection Interface by K6XX:
    Lucky for me, K2KW needed a safe place to store his FT-1000MP. Upon volunteering for baby-sitting duty, I faced the problem of interfacing the new rig into my (mostly) automated station. Most importantly, the DuneStar bandpass filter bank required control. Eliminating the audible noise and delay problems caused by the amplifier control relay meant adding a solid-state buffer. Since the `MP has an 8-Pin DIN jack on the rear panel that includes both the band control lines and the T/R line, one small box could do the job.
    The Design
    A little experimentation with a voltmeter showed the BAND DATA jack uses 5V logic with the bands encoded in BCD format (see Table 1). Comparing this table with the 7445 BCD to 1 of 10 decoder/driver ICs showed a match. Furthermore, the 30V/100mA rating of the open-collector outputs on the 7445 made the old TTL IC a perfect match. Beside providing a +5V supply, no other active devices are needed for the band interface.
    FT-1000MP Band Selection and Amplifier Keying Interface
    Table 1. BAND DATA Code
    BAND DATA Band
    D C B A
    0 0 0 0 —
    0 0 0 1 160m
    0 0 1 0 80m
    0 0 1 1 40m
    0 1 0 0 30m
    0 1 0 1 20m
    0 1 1 0 17m
    0 1 1 1 15m
    1 0 0 0 12m
    Some RF problems in the prototype lead to the 220 ohm resistors in series with each input and the inductors in the output lines. Neither inductor nor resistor values are critical; resistors should not be much larger due to the input current of the 7445 (remember, this is old-style TTL).
    My second version uses an IRF510 N-channel MOSFET as the keying transistor. Now, the Key Line output is rated to 100V and 5A, just in case some strange amplifier needs that capability. With a MOSFET output, the 2.2k ohm resistor becomes 22k ohm and the 1N4001 diode is unnecessary. One final option is a switch that disables the DuneStar power when SWLing; even megapower broadcasters are hard to copy when the filters chop them out!
    Table 2. FT-1000MP BAND DATA Jack Pinout
    DIN # Name Function
    1 +13V Aux. power supply output
    2 TX GND Open collector T/R switch, active low
    3 GND Ground
    4 BAND DATA A See Table 2
    5 BAND DATA B See Table 2
    6 BAND DATA C See Table 2
    7 BAND DATA D See Table 2
    8 TX INHIBIT Handshake*
    * Ensures amplifier is ready for RF power. Not used in this interface.
    BAND DATA Pin 2, TX GND, is an open-collector output that SHOULD be perfect for driving amplifiers, QSK or otherwise. Unfortunately, Yaesu chose to use a wimpy little transistor that can only handle 15V at 100mA. The 15V is too low for my Alpha, and the 100mA is too marginal for my Ameritrons, especially with the Relay Accelerator circuit employed. Since every rig must operate with every amplifier in case anything breaks during a contest, all interfaces must handle the worst-case combination, meaning the TX GND output needs buffering.
    NOTE: the TX GND mentioned here is Pin 2 on the BAND DATA connector, not the dedicated phono jack output on the rear panel of the `MP. The phono jack output is from the internal relay and is disabled when the LIN SW is turned OFF; the DIN output remains active regardless of switch setting. The buffer consists of two transistors, each connected as a basic inverter.
    Circuit Implementation
    The design is nearly complete. The 5V regulator needs two capacitors of noncritical value. Power dissipation for the TO-92 package is 360mW; a bit high. Adding a 100 ohm, ½W resistor in the input lead (between the DIN pin and the capacitor, not between the capacitor and the regulator) reduces IC heating. Or, like me, you could use a TO-220 regulator package instead. The circuit was constructed on perf-board.
    Operation
    This is the best part. Once the interface is built and connected, no user intervention is required. Change the frequency of the FT-1000MP and the DuneStar bandpass filter bank switches automatically. Now turn off the LIN EN switch and run silent QSK with "real" amplifiers. "Baby-sitting" has rarely been this much fun!
    Aleksey (ex RW1150M, RA3MB, UA3MEA,RA3MWZ,RA3MBP )
  2. #6632
    Эртильский р-он Воронежская обл
    270
    RA3QTT
    Кто работает на 2х ГИ7Б. Каким должен быть ток сеток при настроенном П-контуре?
  3. #6633
    Аватар для R6CA
    Новороссийск
    194
    R6CA
    Все зависит от напряжения анода и мощности раскачки, но не должен превышать 30% анодного тока.
    73! Вадим SS2Pro/SPE1.3K-FA/IC7300/TS480remout/TA-53-M/IV30/IL40-160
  4. #6634
    15,680
    При увеличении уровня раскачки растёт ток анода и ток сетки.
    При каком то максимальном уровне раскачки, рост тока анода замедляется, а ток сетки растёт по прежнему.
    Это граница. Чуть уменьшаем раскачку и это максимум.
    При подстройке анодного контура, мощность на выходе растёт, ток анода немного уменьшается, а ток сетки немного увеличивается. Это оптимум настройки . Больше выжать не пытайтесь.
  5. Спасибо от RA3QTT Николай
  6. #6635
    Аватар для SENE
    Россия
    3,799
    ex RC3XG, RC4HC, RZ4HX, RA4HMW)
    Надеюсь, не вызову нареканий.
    Так проще сказать в эфире, без рекламы своей страничке на ютубе ... " ... можете посмотреть на ... , как делал корпус и шасси. ..."
    Николай, R4IJ
  7. Спасибо от dvi, tomcat
  8. #6636
    Аватар для Volandus
    Задворки Европы
    1,015
    RU4AA
    Не более 120ма
    "Когда орлы молчат- болтают попугаи!" Сэр Уинстон Черчилль.
  9. Спасибо от RA3QTT Николай
  10. #6637
    Николаев
    13,753
    UR5ZQV
    RA3QTT Николай, Вы предполагаемый режим дайте (импулс тока и напряжение анода), стопорить там может только допустимая мощность сетки, 7Вт (если все охлаждать по ТУ).
  11. #6638
    Аватар для SENE
    Россия
    3,799
    На 80/40 М, придется "пристегивать" дополнительные емкости ...
ID:	350834   Нажмите на изображение для увеличения.
ID:	350835   Нажмите на изображение для увеличения.
    Николай, R4IJ
  12. #6639
    Для информации: в усилителе на паре ГИ-7БТ на 28 МГц вполне достаточно и "непеределанного " КПЕ типа от РСБ-5.
    Для более "емких" ламп такой КПЕ конечно придется переделывать.
    Последний раз редактировалось AL.X; 02.02.2021 в 17:12.
    73 ! ALEX **#*
  13. #6640
    Аватар для UT1LW
    Харьков
    4,048
    UT1LW
    Ну в оригинале, там есть эксцентрик на оси, отключающий кондер от цепи и можно поставить доп.маленький переменник для 28.
    Вячеслав, ex UT5TX.
  1. PL-880 и другие
    от Sergey_4z5ky в разделе Трансиверы, приемники КВ/УКВ
    Ответов: 78
    Последнее сообщение: 30.08.2023, 22:56
  2. Поворотки П-8, П-10, П-12, П-18 и другие
    от UA6BQQ в разделе Антенная механика
    Ответов: 26
    Последнее сообщение: 01.10.2012, 18:46
  3. Приемник AR-88 и другие
    от в разделе Трансиверы, приемники КВ/УКВ
    Последнее сообщение: 21.03.2010, 21:40
  4. СВЧ триоды для LNA?
    Ответов: 32
    Последнее сообщение: 20.04.2008, 19:24
  5. В усилителе мощности какие лучше применять триоды
    Последнее сообщение: 31.05.2006, 14:50
