Страница 571 из 626 ПерваяПервая ... 71471521561568569570571572573574581621 ... ПоследняяПоследняя
Показано с 5,701 по 5,710 из 6256
Тема: FLEX 6000
  1. #5701
    Аватар для ur5mid
    Киев
    952
    UR5MID, UW8U, UT5M
    Remote Keyer Interface for Flex 6000
    Remote Keyer Interface for Flex 6000 Series RemoteKeyerInterface@groups.io
    What is this?
    RemoteKeyerInterface is a simple program that lets you connect a hardware Winkeyer to your PC to allow paddles to key a remote Flex 6000 transceiver while the Winkeyer generates local side tone.
    How to Download?
    The installer is available at the following URL:
    https://s3.amazonaws.com/nq6n/Remote...ce/publish.htm
    Serial port interface documentation is available as a PDF:
    https://groups.io/g/RemoteKeyerInter...to%20RS232.pdf
    How does it work?
    You connect a serial cable (or USB serial adapter) to the RCA connectors for PTT and KEY on the back of the Winkeyer. When you send paddle CW with a paddle connected to the Winkeyer, the RemoteKeyerInterface program monitors the KEY and PTT state via the serial connection and sends this keying information to the remote Flex 6000 series transceiver you have selected.
    How to set it up?
    First, prepare a serial port connection. Two methods of connecting the serial port are available, one that uses the correct method, as well as a shortcut method that relies upon passive pulldown. Both methods work with a Winkeyer USB or other keyer that has isolated PTT and KEY outputs.
    KEYER CONNECTION
    Starting the program and connecting to rig and serial port
    Double click on the program icon called RemoteKeyerInterface, and select a rig from the top dropdown list. The software must be able to see the rig either via LAN or VPN. Smartlink support is not yet available but is coming soon.
    Then, in the second dropdown list, choose the serial port that you have connected to the Winkeyer's PTT and KEY outputs.
    Now, when you send CW with a paddle connected to the Winkeyer, the software will key your Flex 6000 series transceiver. You will hear CW side tone coming from the Winkeyer's tiny internal speaker. This sidetone does not sound particularly nice, but it has no latency which is useful for hand sent CW.
    Future Improvements
    • Generate low latency sidetone from the PC instead of relying upon the Winkeyer's own sidetone.
    • Adjust the sidetone pitch to match the pitch configured in SmartSDR
    • Add Smartlink support
    Frequently Asked Questions
    Q: Is the Winkeyer's built in serial or USB port used?
    A: No, it is not necessary for the proper functioning of this program.
    Q: Will SmartSDR one day support side tone and serial port paddle connections?
    A: Flex has not announced whether it will, but this program is meant as an intermediate step. Ideally this program will be made obsolete once such functionality is added.
    Q: Why is there a checkbox for sidetone? Why is it disabled?
    A: This checkbox is meant to indicate that PC sidetone support is coming, but that it is not available yet.
    Q: Can I connect the Winkeyer's built-in serial/USB port to N1MM+ and use this program to send CW and generate sidetone for CW sent using N1MM+?
    A: This should work, but it has not been tested extensively. Please post to the group if you use this successfully.
    Q: Why haven't you added PC side tone yet?
    A: It has been challenging to find a way to generate low latency sine wave audio on the PC. There are some libraries that I have not yet had a chance to try. If you have expertise in this please email NQ6N.
    Q: Why haven't you added Smartlink support yet?
    A: I have the login working, but for some reason the radio connection is not yet working. I have had very little time to spend on this. If you have expertise in this and wish to help debug, please email NQ6N.
    Serge UR5MID
  2. #5702
    Смоленск
    1,511
    UA3LМ
    сегодня хотел поставить на комп слайс мастер,флекс метер но программы не коннектятся с флексом . флекс подключен по лан , а интернет раздаю телефоном через USB. В сетевых настройках вижу две сети , одна с допуском в интернет а вторая без . Та что без допуска в интернет ip не совпадает с ip флекса , та что с допуском в интернет тоже ip другой . может нужно через роутер флекс с компом соединять ? Почему на прямую программы не видят флекс? может подскажет кто идею . возможно подружить эти программы без интернета ? или вручную ip нужно прописывать ?
    Последний раз редактировалось sgk; 22.02.2020 в 20:46. Причина: Исправлено намеренное искажение русского языка
    с откуда работаешь,что на выходе?!
  3. #5703
    Аватар для R5AU
    2,722
    ex RA3AJK
    я имел ввиду что здесь в PDF
    ----> https://groups.io/g/RemoteKeyerInter...t o%20RS232.pdf
    и что под этой ссылкой
    .....PTT and KEY outputs.
    ----->KEYER CONNECTION
    Starting the program and connecting to rig and serial port....
    Сергей, R5AU
  4. #5704
    Аватар для ur5mid
    Киев
    952
    UR5MID, UW8U, UT5M
    По ссылке под pdf выскакивает страница с тем же текстом, что я сообщил. По keyer connection выскаивает ошибкаНажмите на изображение для увеличения.
    Последний раз редактировалось ur5mid; 22.02.2020 в 21:17.
    Serge UR5MID
  5. #5705
    Самара
    757
    RO4I
    Поделитесь кто какой скиммер использует с флексом?
  6. #5706
    Аватар для R5AU
    2,722
    ex RA3AJK
    разновидностей скимеров немного ), использую SDC
    Сергей, R5AU
  7. #5707
    Самара
    757
    RO4I
    Спасибо. Скачал тот который в документации n1mm а он начал требовать 5тр - это было неожиданно :(
  8. #5708
    Аватар для R5AU
    2,722
    ex RA3AJK
    напишите Алексу, для отечественного р\л скидка будет
    Сергей, R5AU
  9. #5709
    Аватар для RN3KK
    Воронеж
    1,003
    RN3KK
    Я иногда использую канадский скиммер, потому как давно на шару перепал ключ от разработчика.
  10. #5710
    Смотрю народ при замерах активно пользуется S-метрами в аппаратах. А просветите, "S" метры у Флексов (ну заодно и в SunSDR) могут настраиваться чтобы показывали среднеквадратическую мощность? А то если они как обычно (и по стандарту) для S-метров используют квазипиковый детектор и экспонециальное усреднение, то им нельзя измерять мощность шума или смеси сигнала+шума (только уровни однотонового сигнала без шума можно сравнивать), иначе можно всяких чудес намерять ...
    С Уважением,
    Олег
  1. Flex-1500
    Ответов: 1660
    Последнее сообщение: 04.01.2024, 18:55
  2. Flex-5000 vs Flex-3000
    Ответов: 22
  3. Некоторые особенности поведения Flex-3000 и Flex-5000 при перестройке частоты
    от UB1ACT в разделе Software Defined Radio (SDR), Digital Radio Mondiale (DRM)
    Последнее сообщение: 16.02.2012, 17:46
  4. GZV-6000
    от ua0foo в разделе Трансиверы, приемники КВ/УКВ
    Последнее сообщение: 15.04.2008, 16:37
