Страница 115 из 128 ПерваяПервая ... 1565105112113114115116117118125 ... ПоследняяПоследняя
Показано с 1,141 по 1,150 из 1275
Тема: Синтезатор за полчаса
  1. #1141
    Собрал другую версию.
    https://janoc.rd-h.com/archives/649
    Правда там LCD 1602, завелось все без проблем на той же меге.
    Вот и думаю, что не так было.
  2. #1142
    Можно ли что то придумать в прошивке, что бы при медленном повороте энкодера (точная настройка) менялись бы условно кГц, а при быстром вращении, условные мГц. Так легче без доп/кнопок перестраиваться.
  3. Спасибо от hamster
  4. #1143
    Написал сегодня автору, вот ответ.
    Скрытый текст
    Hello!
    Yes, I saw your query (message 1136) on cqham.ru on the same topic.
    (Google Translate is a wonderful help!)
    Your fuse settings are correct.
    I should also say, the project does work correctly, in case someone says
    "Oh, that design doesn't work properly". It has been successfully copied
    many many times by others.
    However, I have noted two problems over the past few years:
    First, the performance of the Nokia LCD displays does seem to vary. The
    problem appears to be caused by the possible use of lower cost
    "PCD8544-compatible" controller chips in China. The result is the
    contrast settings that worked on all Nokia displays for, say, 15 years,
    do not always work these days with Chinese-supplied "PCD8544-compatible"
    displays. My source code for this VFO is still available on my website
    for download so you might try varying those settings. I have not
    established a recommended value for these Chinese LCDs. Actually, I have
    thought that these may be faulty, perhaps rejects from the production
    line, since they sometimes do not do other things that the
    specifications say the LCD controller should do.
    Secondly, I have been able to program the ATmega328 chips successfully
    at 3.3V which is in complete agreement with the specifications in the
    datasheet. For example, Figure 28-7 in the datasheet states the chip can
    be programmed and verified with a supply voltage of 1.8 to 5.5V. So
    programming at 3.3V works just perfectly. I regularly use my USBasp at
    3.3V and 5V without any problems.
    However, a problem that builders may encounter is if they try to program
    this design with 5V. The Si5351a is not rated for operation at this
    voltage, and the (compatible) PCD8544 controller in the Nokia LCD
    display is specified to operate at no more than 3.3V. The circuit shows
    these chips are connected to the common supply rail with the ATmega328.
    Yes, the "Limiting Values" table in the specifications for the PCD8544
    says it has a maximum VDD of 7V but it is not clear if the Chinese
    compatible devices can survive this voltage.
    So, if builders program their ATmega328 in the PCB using 5V, the VFO may
    no longer operate. I have highlighted the maximum programming voltage of
    3.3V on the circuit diagram and in the webpage but....I cannot hold
    every builder's hands.
    Последний раз редактировалось sgk; 10.08.2023 в 21:21. Причина: язык форума русский
  5. #1144
    А, не проще своими словами на русском.
    Сославшись на источник. Всё-же сайт русскоязычный.
  6. #1145
    Аватар для IG_58
    Германия
    13,014
    18
    Простыми словами - всё в прошивке правильно, всё у всех работает, а если не работает, то, вероятно, китайский дисплей - брак / некондиция. И не пытайтесь шить на 5В, шейте на 3,3В.
    Игорь
  7. Спасибо от hamster
  8. #1146
    Простыми словами
    Ну вот, и не надо пол страницы занимать
  9. #1147
    ст. Тащиловка
    1,094
    RA4FKV R4FAM
    Цитата Сообщение от seybr Посмотреть сообщение
    Вложение 247672В приведенной схеме синтезатора применяется микросхема FXMA108. Какая ее необходимость? Возможность работы без ее установки?
    добрый вечер подскажите а где можно взять архив на эту схему (прошивку и описания)
  10. #1148
  11. Спасибо от Neymeka
  12. #1149
    ст. Тащиловка
    1,094
    RA4FKV R4FAM
    veso74,спасибо большое Привет всем а кто повторял или нет если повторял то как в работе
  13. #1150
    Приветствую друзья!
    Разгребая архивы старых материалов, наткнулся на вот такую интересную конструкцию синтезатора, описанную Владимиром Карпелянским ТУТ и повторённую Петром UB4AEM ТУТ, хвосты которой нашлись в этой ветке аж в 16 году.
    Синтезатор для "Аматора" на красивом дисплее. На 16 год это было интересно, но почему-то осталась сообществом без внимания. Все залипли на классическом 2х строчном LCD, хотя, этот экранчик стоит не намного дороже, а выглядит сильно интереснее. Примечательно, что подобная конструкция выполнена на атмеге 328 и аналогом подобной конструкции нашлась всего одна схема от UT5QBC, известная как "Микроб", но она выполнена на СТМ32Ф100 (опробовано, работает).
    Т.к. исходники синтезатора открыты и в адруино-среде модифицированы Александром R2DHG по следам конструкции этой ветки под цветной экран, который есть в наличии, то решил по-быстрому собрать в живую на адруинке и посмотреть как оно будет работать. В среде IDE 2.1.1 всё благополучно собралось, залилось в адруину нано, экран моргнул и.... и всё. Чёрный экран и никаких реакций.
    В то же время, у людей эта конструкция вполне реально работала вот в таком виде, собственно как я и повторил навесом в проводах.
    Вчера был потрачен весь вечер в безуспешных попытках завести конструкцию.
    Сборка в разных версиях сред, с разными библиотеками, на 2х разных экранах и 3х разных платах адруино, включая перепайку 5В стабилизатора на 3.3В. Везде один и тот же результат - экран проходит инициализацию, закрашивается чёрным и дальше тишина.
    В общем, требуется помощь зала или автора Александра R2DHG, в какую сторону копать?
    Из дальнейшего, хотелось бы попросить помощи модифицировать код для ПЧ 9МГц для простого телеграфного трансивера.
    В коде обнаружились закомментированные модули под 4 диапазона. Сейчас из 3, почему - это как бы понятно из логики применения для аматора 160/80/40 для ПЧ 500кГц. Если можно поправить код под ПЧ 9МГц, то интересно было бы и 5 диапазонов под простой походный трансивер.
    Но, пока проблема просто запустить вроде бы максимально простую конструкцию.
    Прикладываю архив, что удалось найти по теме: исходный вариант на АД9850, который был потом модифицирован в си5351. (скетч для АД9850 ни в каком виде не смог собрать)
    (Скетч с библиотеками, схема и плата в диптрейсе)
Название:	2023-08-20 12_38_56-Schematics - [C__Users_Admin_Desktop_Синтезатор_Синтезатор Аматора- Схема.dc.png
    Последний раз редактировалось DerBear; 20.08.2023 в 12:53.
  1. Сдох синтезатор
    от RM9WY в разделе FT-817
    Последнее сообщение: 17.03.2015, 17:10
  2. Синтезатор
    от Сереня в разделе Для начинающих
    Последнее сообщение: 31.07.2014, 14:53
  3. Узел крепления для спайдера за полчаса
    от ГУН в разделе Антенная механика
    Ответов: 18
    Последнее сообщение: 07.10.2012, 18:16
  4. Синтезатор ПЧ
    от geron2008 в разделе Технический кабинет
    Ответов: 15
    Последнее сообщение: 28.03.2011, 12:37
  5. Синтезатор
    от RA0CHE в разделе Конструкции на микроконтроллерах для радиолюбителей
    Последнее сообщение: 22.04.2008, 06:03
