RZ6M скайп посмотрте
Спасибо за уделенное время. Есть вопрос, на представленном кино программа приемника "экс-калибр" работает с USB-аудио устройством айкома, как источником сигнала?
И если тоже самое в SSB или CW режиме продемонстрировать на любительском диапазоне, то полоса в районе центра 12кГц еще меньше будет?
...только с выходом AF/IF 12кГц , звук пишется с WR (тут все оригиналы https://cloud.mail.ru/public/E2H2/Xq6i54PJa )
Спасибо от Serg
Видимо к программе надо ключ иметь или приемник? Скачал, но дает только демо-режим.
Добавлено через 48 минут(ы):
Еще из рассылки о перегрузе:
Скрытый текст
I encountered OVF conditions e arly one e vening a few weeks ago on 20 meters from Radio Habana on 13.740 Mhz. Habana's signal was right around s9+60 even with the preamp off and the r ange between 12 Mhz and 15 Mhz=had a number of =mixing products between Habana and other SW Broadcasters=in =the 13.8 Mhz range. It also affec ted 30 meters on a quick test.
I could kill the OVL by manipulating the RFG, putting in the ATT or switching in my RX bandpass filter which nominally covers 14.0 to 14.4 Mhz. The bandpass filter was the most satisfactory solution since it did not require some sort of RX attenuation, in fact I could turn on Pre 1 with no OVF under this circumstance.
73, Kevin K3OX
With the radio tuned to 14.0 MHz, the OFV light starts to flicker at -10 dBm within the 10 to 15 MHz range of that half-octave filter.
If the signal generator is set to -5 dBm, the OVF just flickers at 7.8 MHz and 16.6 MHz. The bandpass filter has 5 dB attenuation at those two frequencies.
If the signal generator is set to 0 dBm, the OVF just flickers at 7.2 MHz and 18.0 MHz. The bandpass filter has 10 dB attenuation at those two frequencies.
Obviously there are broadcast stations from the 41 meter band (7.2 MHz) through the 16 meter band (17.9 MHz) that could impact the radio when tuned to either 30 or 20 meters.
Rob, NC0B
Clearly the 7300 front end filters are quite broad - 10 to 15 Mhz for example - and the slopes of this filter are only 5dB down at 7.8 MHz/16.6 MHz and 10dB down at 7.2 MHz/18 MHz. However we need to keep in mind that -10, -5 and zero dBm equate to S9+63 dB, S9+68 dB and S9+73 dB. These are enormous signals!
73, Chris ZL2XG/ZL1BOE
Последний раз редактировалось Serg; 15.05.2016 в 13:29.
Сегодня доставили аппарат из Радиоэксперта. По времени всё сделали четко, как и обещали. Пока не видел аппарата - на работе. Теперь на выходных будет что с моим Тексуном сравнить...
Что имеем то и будем сравнивать.
Для меня это будет интересно...
человек на радостях пошутить решил, а Вы всерьёз...
