Страница 1 из 536 12341151101501 ... ПоследняяПоследняя
Показано с 1 по 10 из 5355
Тема: Ретро-радио - регенеративный на лампах #8
    Модератор
    Ялта
    13,657
    Продолжение темы. Старая тема по ссылке
    http://www.cqham.ru/forum/showthread...=1#post1549667
    Сергей sgk.
  2. Спасибо от Ventil
  3. #2
    Аватар для IG_58
    Германия
    13,014
    18
    Вот интересный материал относительно того, каким образом можно было бы определить номиналы резистора и конденсатора "гридлика":
    Скрытый текст
    Here's how I determine the values for the grid capacitor and leak resistor for the regenerative detector -
    1. Make the value of the grid capacitor (condenser) around ten times the total input capacitance of the tube grid (grid to plate plus grid to cathode). This makes the impedance of the capacitor, at the carrier frequency, small in comparison with that of the grid.
    2. The time constant of the grid leak and condenser should be no greater than one fifth of the period of the highest modulating frequency to be reproduced, in order for the grid voltage to follow the modulation envelope quickly enough to not reduce the amplitude and distort the waveform of the recovered modulating frequency excessively.
    Using these guidelines, the values can be determined:
    1. Choose the condenser value:
    For example, the grid input capacitance of tube type '01A is published as very close to 11 pF. So, 10 x 11 = 110 pF. The closest common value is 100 pF, it will work perfectly well here.
    2. Calculate the maximum value for the grid leak:
    If the highest modulating frequency to be reasonably well reproduced is say, 3500 Hz, then 1/3500 = 286 uS. 286/5 = 57 uS. 57 uS divided by 100 pF = 571,429 ohms as the maximum for the grid leak. The closest standard 10% value is 560 k.
    So, 100 pF for the condenser and 560 k ohms for the grid leak are suggested, in the example case given.
    Of course, experimentation with values up to two or three times higher and lower may be appealing so as to develop a feel for the effect they may have on the audio, regeneration control, sensitivity, etc.
    http://www.antiqueradios.com/forums/...60023&start=20
    Краткое содержание, суть:
    1. Величина емкости ориентировочно в 10 раз выше, чем суммарная емкость (сетка-катод + сетка-анод) лампы.
    2. Величина сопротивления выбирается исходя из постоянной времени RC-цепочки гридлика, которая должна составлять не более одной пятой периода максимальной частоты модуляции.
    Пример:
    1. Для лампы 6Ж8 емкость гридлика составляет примерно 10 х (6 + 7) = 130 пф.
    2. Для этой же лампы и
    максимальной частоты модуляции 6кГц (период = 1/6000 = 167мкс, одна пятая будет 33мКс, делим на емкость 130 пф, получаем максимум 254 кОм.
    Это те ориентировочные значения, с которых нужно начинать, а практическое изменение этих параметров в 2-3 раза туда-сюда подскажет, как получится лучше.
    Последний раз редактировалось sgk; 28.07.2018 в 10:26. Причина: Язык форума русский.
    Игорь
  4. Спасибо от Boris.., Gorlo_A, Hans03, NIC49, olegau, Stalker, wolf1605
  5. #3
    При макетировании можно использовать набор емкостей и сопротивлений, коммутировать джамперами в любой комбинации. И пробовать при различных режимах каскада.
  6. #4
    живу здесь Аватар для RA4UKJ
    Мордовия, г. Саранск
    722
    20
    RA4UKJ
    Поздравляю всех с 8 веткой темы!
    и днем ВМФ
    Сергей ra4ukj@gmail.com
  7. Спасибо от hamster, Henriks.V, IG_58, long, mmom, NIC49, svoy 3000
  8. #5
    Модератор
    Ялта
    13,657
    Лампа, нестандартное питание
    Сообщения ранее об отборе ламп
    http://www.cqham.ru/forum/showthread...=1#post1549611
    http://www.cqham.ru/forum/showthread...=1#post1549650
    для работы в схеме регенератора с "батарейным" питанием. Под батарейным напряжением понимается 12,6 В напряжение аккумулятора из двух банок по 6,3 В. Оставшиеся 6 ламп 6Ж1П проверил при напряжении анодной цепи 21 В - 26 В. В результате 4-ре лампы заработали в схеме регенератора (индуктивная трёхточка) но со смещением 0,1 В или выше на первую сетку. Две лампы не заработали. Попробовал для схемы регенератора лампы 6Ж52П. Одна из ламп заработала при анодном +26 В и смещении 0,1 В на первой сетке. В общем приобретение Б/У ламп на рынке для работы с низким анодным напряжением лотерея, повезёт или не повезёт.
    Сергей sgk.
  9. #6
    Аватар для IG_58
    Германия
    13,014
    18
    Может быть, имеет смысл не играть в лотерею, а так повысить анодное напряжение, чтобы лампа надежно заводилась?
    Игорь
  10. Спасибо от Boris.., long, NIC49
  11. #7
    - у многих ламп (например 6ж7 ) указан режим анодного 26 вольт не пробовали?
  12. #8
    Аватар для Boris..
    Czechy, JO70AQ
    1,983
    OK9ZBA
    я тоже не понимаю смысла использовать низкое анодное напряжение. Зачем?
    Время, потраченное на изыскания "будет-не будет работать" лампа при низком анодном лучше использовать на создание приличного лампового БП на паспортные значения анодного напряжения.
  13. Спасибо от standby
  14. #9
    Когда то задавался вопрос - были ли промышленные образцы приборов с низким анодным. Есть ИРК-2 - Испытатель радиокомпасов, питается от бортсети авиатахники 27 В +- 10%. В нем ДВ - СВ ВЧ генератор с модулятором на двух пальчиковых лампах, умформера нет, анодное - 27 В. Прибор имеется, ТО нет, доберусь - посмотрю, какие лампы.
  15. #10
    Модератор
    Ялта
    13,657
    Кроме просто любопытства при каком анодном напряжении может работать лампа в схеме регенератора для этого специально не предназначенная, есть желание запитать схему от USB порта ноутбука. Это 5 В без каких либо преобразователей.
    Такой лампы нет, на радиорынке лампы этой серии были такие ржавые что покупать не стал. При случае и наличии рабочей лампы проверю. Пока результаты такие: напряжение накала 5 В (напряжение в случае питания от USB) некоторые лампы 6Н1П работаю при анодном 10-12 В и нувисторы 6С52Н. Лампа 6Н23П работает от 0,5 В анодного и накальном 5 В. Нравится лампа 6Ж1П из-за "меньшего" тока накала (0,17 А) в сравнении с 6Н23П. Но не могу заставить работать этот экземпляр при 5 В анодного. Работает при 5,8 В анодного и положительном смещении на первую сетку. Накал 5 В.
Название:	6Ж1П 5_8 В питания на аноде лампы.png
    Сергей sgk.
  1. Ретро-радио - регенеративный на лампах #7
    от RU9CA в разделе Старое радио (Ламповые души)
    Ответов: 12190
    Последнее сообщение: 27.07.2018, 20:46
  2. Ретро-радио - регенеративный на лампах #6
    Ответов: 1127
    Последнее сообщение: 11.04.2012, 05:11
  3. Ретро-радио - регенеративный на лампах, своими руками #5
    от UA6AP в разделе Старое радио (Ламповые души)
    Ответов: 5370
    Последнее сообщение: 10.02.2012, 17:48
  4. Ретро-радио - регенеративный на лампах, своими руками #3
    Ответов: 1789
    Последнее сообщение: 13.04.2010, 21:09
  5. Ретро-радио - регенеративный на лампах, своими руками #2
    Ответов: 2164
    Последнее сообщение: 16.09.2009, 13:20
