Страница 3 из 13 ПерваяПервая 123456 ... ПоследняяПоследняя
Показано с 21 по 30 из 130
Тема: Работа в APRS через программу JS8Call
  1. #21
    Модератор Аватар для DL8RCB
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    Цитата Сообщение от RK1AT Посмотреть сообщение
    144.168 mhz
    Юра спасибо, бакен c периодом 7мин включен.,правда антенна пока на восток
    знаешь ли ссылку на сервер ?
  2. #22
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    тишина в сторону Востока, на 144174 станции есть
    https://docs.google.com/document/d/1...h.5386t3ql3k6h
    • QTC - Send station message
    • QTH - Send location message
    • GRID - Send a long-form grid locator (to be spotted on a map via PSKReporter & APRS-IS)
    • QSL? - Did you receive my last transmission?
    • QSL - I received your last transmission
    • YES - I confirm your last inquiry
    • NO - I negative confirm your last inquiry
    • HW CPY? - How do you copy?
    • RR - Roger. Received. I copy.
    • FB - Fine Business
    • QRZ? - Who is calling me?
    • 73 - I send my Best Regards / End of Contact
    Последний раз редактировалось DL8RCB; 23.10.2018 в 18:49.
  3. #23
    Обновление программы до версии 0.8.1
    The latest version of JS8Call is 0.8.1:
    MacOS:
    https://s3.amazonaws.com/js8call/0.8...vel-Darwin.dmg
    Windows:
    https://s3.amazonaws.com/js8call/0.8...evel-win32.exe
    RaspberryPi:
    https://s3.amazonaws.com/js8call/0.8...h.ARM.AppImage
    https://s3.amazonaws.com/js8call/0.8...evel_armhf.deb
    Linux:
    https://s3.amazonaws.com/js8call/0.8...86_64.AppImage
    https://s3.amazonaws.com/js8call/0.8...6.04_amd64.deb
    https://s3.amazonaws.com/js8call/0.8...8.04_amd64.deb
    https://s3.amazonaws.com/js8call/0.8...devel_i386.deb
    Скрытый текст
    Disable stations heard command:
    Ripped out decoded.txt and houndcallers.txt junk
    Added menu for decode depth. Removed some WSPR.
    Moved relay responses into the main window
    Simple buffered directed commands should log immediately
    Reduce late start to 25%
    Removed temp txt file
    Expose transmit delay in configuration
    Do not delete band activity or call activity rows that are selected
    Experiment trying to extend compound callsigns
    Added validation message for callsigns
    Working compound extended callsigns with group identifiers
    Compound callsigns and group callsigns parse correctly
    Added autoprepend back in
    Don't allow compound calls greater than 9 chars
    Added configuration for groups
    Replace GROUPCALL with actual group calls
    Replace ALLCALL with @ALLCALL
    Updated configuration tooltip and validation
    Bump to v0.8.0
    Remove table configuration from context menu
    Added macro like functionality for saved messages
    Idle minutes should always be incremented
    Hashed messages have a 16-bit checksum instead of a 32-bit checksum
    Added SK short message
    Warning message for stupid messages
    Do not allow text overrides for selected calls during parsing
    Macro for CQ, Reply, QTH, QTC messages
    Added default macro for CQ message
    Bump eol
    Rename beacon to heartbean with pings and ping acks
    Heartbeat commands instead
    Fixed idle timer for idle watchdog
    Better interface for idle timer values
    Replaced character queries with textual queries to make it easier to read
    Time drift columns and show column labels
    Tweak decoder for better decodes under poor conditions
    Average time delta computation
    Restructured data frame packing so we can send more over the wire in fewer frames
    Better labeling
    Reduce late start threshold to 2 seconds
    Fixed typo in varicode
    Update threshold and tones. Cleanup bits
    Average time drift labels
    Rig name in title
    OCD
    15 seconds is not now
    Added worked before status
    Added compatibility parsing for commands
    Update heartbeat to allow on demand only. Add AUTO requirement for ACKs
    Time drift button labeling
    0.8 is not backwards compatible
    _._,_._,_
  4. #24
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    Юра спасибо,результата на 2-ке нет," бакен с 10-ю элементами яги" смотрят на восток
  5. #25
  6. #26
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    Очередное обновление. версия 0.8.2
    пока не увижу в pskreporter с кем можно попробовать, нет смысла менять версии.
    сутками "кидать" бакен не особо интересно, не вижу пока в европе, кто пробует с моей стороны.
    ранее на 144,174 проскакивали Россия и Белоруссия в ft8.(но только на прием)
    Последний раз редактировалось DL8RCB; 06.11.2018 в 12:51.
  7. #27
    Версия 0.8.3
    The latest version of JS8Call is 0.8.3:
    MacOS:
    Windows:
    RaspberryPi:
    Linux:
    Изменения:
    Fixed more issues with compressed data decoding and invalid frames
    Fixed macro expansion for auto-reply messages QTC and QTH
    Fixed call activity with empty rows
    Fixed OSX issue with menuBar menus that have sub-menues that aren't populated at construction, but when the menu is aboutToShow
    Fixed bug with space collapsing in displayTextForFreq
    Added TU short command
    Added TDELTA macro variable
    Bump to v0.8.3
  8. Спасибо от DL8RCB
  9. #28
    Ярославль
    51
    R3MAZ
    Доброго дня! Когда работал на UIVIEW32 видел себя на карте aprs.fi
    В программе JS8Call как можно определить коннектится она сайт или нет.
    Трансивер еще не подключал.
  10. #29
    DKD
    В программе JS8CALL нужно активировать в настройках отправку спотов и бакенов APRS
    Скрин настроек прилагается.
    Если ваш бекон(маяк) сигнал будет принят корреспондентом в эфире и декодирован программой JS8CALL, в которой активирован режим APRS, то эта программа отправит спот на указанный в настройках сервер APRS и ваше местоположение (координаты бекона-маяка) будет отображено на карте, смотреть на aprs.fi
    При работе программой JS8CALL не нужны звуковые модемы и программа Ui-View32.
    достаточно ввести данные позывного и координаты квадрата 10 знаков (данные о квадрате с точностью до метров
    Эти данные можно получить здесь
    Последний раз редактировалось RK1AT; 09.11.2018 в 19:07.
  11. #30
    94157 Perlesreut
    16,247
    DL8RCB, ex UW9EZ
    нужно активировать отправку спотов
    это сделано
  1. работа форума APRS
    от DL8RCB в разделе APRS и другие виды пакетной связи
    Ответов: 82
    Последнее сообщение: 16.06.2016, 15:11
  2. Работа через дробь
    от RV3 в разделе Правовой практикум радиолюбителя
    Ответов: 137
    Последнее сообщение: 02.06.2014, 14:20
  3. Работа через PCSat2
    от K6VHF в разделе Программы для УКВ
    Последнее сообщение: 22.03.2011, 21:29
  4. Проги и их работа через прокси
    от Ferz в разделе Программное обеспечение
    Ответов: 55
    Последнее сообщение: 08.04.2008, 14:37
