Доброго дня, всем! Ищу мануал, сервис-мануал, софт к старичку ICOM IC-U12.
Type: Professional UHF transceiver
Frequency range: 406-470 MHz
Mode: FM
RF Power output: 3 W
Receiver system: N/A
Sensitivity: N/A
Selectivity: N/A
Image rejection: N/A
Voltage: ? VDC
Current drain: RX: ? mA
TX: Max ? mA
Impedance: 50 ohms, BNC
Dimensions (W*H*D): 65*117*45 mm (without battery)
Weight: 590 gr (with CM5 battery and antenna)
Manufactured: Japan, 19xx-19xx (Discontinued)
Other: 12 channels, programmable via diode matrix
