Transmitter Parameters |
Transmitter Architecture |
SDR |
Transmission Mode |
SSB, CW, RTTY, AM, FM |
Frequency Resolution |
1Hz |
Transmit Frequency Range*1 |
1.800-2.000Mhz, 160m
3.500-3.900Mhz, 80m
5.351.5-5.366.5Mhz, 60m
7.000-7.300Mhz, 40m
10.100-10.150Mhz, 30m
14.000-14.350Mhz, 20m
18.068-18.168Mhz, 17m
21-21.450Mhz, 15m
24.890-24.990Mhz, 12m
28-29.7Mhz, 10m
50-54Mhz, 6m
144-146/148Mhz, 2m
430-450MHz. 70cm |
Output Power |
HF+6m:SSB(1~20W),CW( 0.1~20W), FM(0.1~20W), AM(1~5W),
VHF: SSB/CW/FM(0.5~5W)
UHF:SSB/CW/FM(0.5~5W) |
Power Consumption |
TX:13.8V~5A
RX:13.8V~0.25A(Norma l),0.35A(Max brightness&Highest audio) |
Carrier Suppression |
<50db |
Spurious Suppression |
1.8—54MHZ: ≥50db
144—146MHZ: ≥60db
430—440MHZ: ≥60db |
Memory Channel |
999 |
Receiver Parameters |
Receiver Architecture |
SDR |
Receiver Mode |
Receive Frequency Range |
300KHz-1.6GHz*2 |
IF Bandwidth |
20KHz |
IF |
12KHz |
Sensitivity*3 |
SSB/CW:(BW: 2.4kHz @ 10dB S/N)
0.18uV(1.8—54MHZ),
0.25uV(144—146MHZ),
0.25uV(430—440MHZ)
AM:( BW: 6kHz @ 10dB S/N)
15uV(0.3—1.8MHZ),
2uV(1.8—54MHZ),
2uV(144—146MHZ),
2uV(430—440MHZ)
FM:(BW: 15kHz @ 12dB S/N)
0.5uV(28.0—29.7MHZ) ,
0.25uV(50—54MHZ),
0.3uV(144—500MHZ),
0.5uV(430—440MHZ) |
IF Suppression |
≥70db |
Image Suppression |
≥80db |
Audio Output Power |
2W (10% distortion rate, 8Ω load, 3KHZ) |
Antenna tuner parameters |
Tuning frequency range |
1.8-54MHZ |
Tuning impedance range |
16.7Ω--150Ω unbalanced (SWR is better than 1: 3) |
Tuning accuracy |
VSWR: 1: 1.5 or less |
Tuning time |
2-5S (full segment 10S) |
Tuning method |
Automatic / Manual |
Spectrum parameters |
Spectrum bandwidth |
48K |
RF Spectrum |
FFT |
Structural parameters |
Size |
190X120X45mm (excluding protrusions) |
Weight |
<1KG |
Working voltage parameters |
Voltage range |
5—32V receiving range,
5-12V transmit power limit,
12-15v UV full power output,
12-18V HF full power output,
15/18-32V prohibits transmit. |
Antenna interface |
Antenna interface |
TNC/BNT/M/N (optional) |
Working environment parameters |
Working temperature |
-10 ℃ to 60 ℃ |
Working humidity |
10% -- 90% |
