Технические характеристики
Specifications
Receiving frequency: 0.55~30MHz 88~108MHz (WFM)
Transmitting frequency:
3.5~4.0MHz
5Mhz (region specific)
7.0~7.3MHz
10.1~10.15MHz
14.0~14.35MHz
18.068~18.168MHz
21.0~21.45MHz
24.89~24.99MHz
28.0~29.7MHz
(Note the listed band frequency range is IARU Region 2, CLICK HERE to learn more about it.)
Operating mode: SSB/CW/AM, WFM (receive only)
Receiving sensitivity:
CW: 0.25uV @10dB S/N
SSB: 0.5uV @10dB S/N
AM: 10uV @10dB S/N
Frequency stability:
±1.5ppm within 30min after power on
@25°C: 1ppm/hour
Transmitting power: ≥5W @13.8V DC
Transmitting spurious suppression: ≥50dB
Audio output power: 0.3W
Operating voltage: 9~15V DC
Standby current: 0.37A @Max
Transmitting current: 2.8A @Max
Dimensions: 4.7*1.6*5.3in | 120*40*135mm
Weight: about 1.6lb | 720g (host only)
Распаковка, обзор, измерения, что внутри
https://youtu.be/2fna9usJun0
