Компилятор выдаёт вот такие предупреждения. Интуитивно предпологаю, что не хватает каких-то библиотек или всё дело в насттройках компилятора. Програмка простейшая.
Из http://forum.radiospec.ru/index.php?showtopic=5612
Листинг 2.
-------- begin --------
avr-gcc (GCC) 4.2.2 (WinAVR 20071221)
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Size before:
AVR Memory Usage
Device: atmega8
Program: 152 bytes (1.9% Full)
(.text + .data + .bootloader)
Data: 0 bytes (0.0% Full)
(.data + .bss + .noinit)
Converting to AVR Extended COFF: avr41.cof
avr-objcopy --debugging --change-section-address .data-0x800000 --change-section-address .bss-0x800000 --change-section-address .noinit-0x800000 --change-section-address .eeprom-0x810000 -O coff-ext-avr avr41.elf avr41.cof
Discarding local symbol outside any compilation unit: .do_copy_data_start
Discarding local symbol outside any compilation unit: .do_copy_data_loop
Discarding local symbol outside any compilation unit: .do_clear_bss_start
Discarding local symbol outside any compilation unit: .do_clear_bss_loop
Warning: no "data" section found in output file
Warning: file C:/WINDOWS/TEMP/ccC6Gftb.s not found in symbol table, ignoring
Warning: ignoring function __vectors() outside any compilation unit
Warning: ignoring function __bad_interrupt() outside any compilation unit
avr-objcopy: --change-section-vma .eeprom+0xff7f0000 never used
avr-objcopy: --change-section-lma .eeprom+0xff7f0000 never used
avr-objcopy: --change-section-vma .noinit+0xff800000 never used
avr-objcopy: --change-section-lma .noinit+0xff800000 never used
avr-objcopy: --change-section-vma .bss+0xff800000 never used
avr-objcopy: --change-section-lma .bss+0xff800000 never used
avr-objcopy: --change-section-vma .data+0xff800000 never used
avr-objcopy: --change-section-lma .data+0xff800000 never used
Size after:
AVR Memory Usage
Device: atmega8
