Power Supply: 13,2 V |
DC Volt Meter |
Oscilloscope |
Frequency Counter |
Preparation alignment:
Clarifier |
Center |
RF Power |
Clockwise |
VR205 and VR206 |
Center |
Remove |
PB 201 |
Step |
Condition |
Adjustment |
Procedure |
1 |
RX AM |
L405 |
Connect the DC Voltmeter to TP2 |
2 |
RX AM |
Same as Step 1 |
3 |
TX AM |
L401 |
Connect oscilloscope to TP1 |
4 |
RX AM |
Check |
Same as Step 3 |
5 |
TX FM |
Check |
Same as Step 3 |
6 |
RX FM |
Check |
Same as Step 3 |
7 |
TX USB |
VR211 |
8 |
RX USB |
Check |
Same as Step 3 |
9 |
TX LSB |
L402 |
10 |
RX LSB |
Check |
Same as Step 3 |
11 |
TX AM |
L406 |
Connect oscilloscope to TP 3 |
12 |
TX FM |
Check |
Same as Step 11 |
13 |
TX USB |
L408 |
14 |
RX USB |
Check |
Same as Step 13 |
15 |
TX LSB |
L402 |
16 |
RX LSB |
Check |
Same as Step 15 |
17 |
RX FM |
Check |
Same as Step 1 |
18 |
RX USB |
Check |
Same as Step 1 |
VFO OSC- TP1 |
Adjust |
X-tal OSC - TP3 |
Adjust |
Mod. |
37.9000MHz |
L401 |
10.6950MHz |
RX - AM |
37.9000MHz |
10.6950MHz |
RX - FM |
37.9025MHz |
10.6975MHz |
L408 |
RX - USB |
37.8975MHz |
L402 |
10.6925MHz |
L407 |
RX - LSB |
37.9000MHz |
10.6950MHz |
L406 |
TX - AM |
37.9000MHz |
10.6950MHz |
TX - FM |
37.9025MHz |
VR211 |
10.6975MHz |
TX - USB |
37.8975MHz |
10.6925MHz |
TX - LSB |
Test equipment required:
DC Current Meter |
Oscilloscope |
RF Power meter |
RF VTVM |
AF Oscillator |
FM Linear Detector |
Dummy Load (50 ohm) |
AF VTVM |
VR208 |
Clockwise |
VR205 and VR 206 |
Middle position |
VR207, VR201, VR202, and VR 203 |
Counterclockwise |
Mic gain |
Clockwise |
Meter SW |
RF |
SWR/CAL Volume |
Middle position |
RF Power |
Clockwise |
Test frequency |
27.185 MHz |
Step |
Condition |
Adjustment |
Procedure |
1 |
LSB 27.185 MHz |
VR203 |
Remove the PB201 |
2 |
Same as Step 1 |
VR201 |
Connect a DC current meter to TP202 (+) and TP201 (-) |
3 |
Same as Step 1 |
VR202 |
4 |
LSB 27.185 MHz |
L221 |
Re-install the PB201 |
5 |
LSB 27.185 MHz |
VR208 |
Adjust for 25 V on the RF VTVM |
6 |
SSB 27.185 MHz |
VR209 |
Adjust the carrier leakade at LSB and USB become minimum and almost equal |
7 |
AM 27.185 MHz |
VR205 |
Adjust for 3.9 Watt on the WattMeter |
8 |
AM 27.185 MHz |
VR204 |
Adjust for RF Meter at "9" just light on |
9 |
AM 27.185 MHz |
VR207 |
Adjust 90% negative |
10 |
AM 27.185 MHz |
VR213 |
Adjust for Modulation Meter at "9" just light on |
11 |
FM 27.185 MHz |
VR206 |
Adjust for 3,9 Watt on the WattMeter |
12 |
FM 27.185 MHz |
VR212 |
Adjust for +/- 1.9 kHz Deviation |
SINAD Meter |
Oscilloscope |
AM/FM SSG |
(AM: 1 kHz 60% Mod.) |
(FM: 1 kHz 1.2 kHz Deviation) |
NB/ANL |
Off |
HI CUT |
Off |
SQUELCH |
Counter clockwise |
Volume |
Clockwise |
RF Gain |
Clockwise |
Clarifier |
Center |
Frequency |
27.185 MHz |
Step |
Condition |
Adjustment |
Procedure |
1 |
AM |
L17 L2 L6 L7 L11 L12 L13 |
Adjust for maximum reading on the AF VTVM |
2 |
FM |
L16 |
3 |
AM |
VR4 |
SSG: 40dB (50uV) Adjust "9" just light on |
4 |
AM |
VR2 |
SSG: 66dB (1mV) Just apper AF level |
5 |
USB |
L15 and L14 |
6 |
USB |
VR3 |
7 |
USB |
VR1 |
SSG: 66dB (1 mV) Just apper AF level |
8 |
USB |
L1 |
Connect Oscilloscope to TP4. Set Oscilloscope to DC range and adjust to reach max. reading. |
9 |
AM |
Check |
SSG: 10dB |
10 |
AM |
Check |
SSG: 10dB |
Quieting of AM reception and improving gain of incoming signals is a common request from radio operators. In the first stages of the HF input 2SC1674 (Q8) transistor can be found. This transistor is responsible for the amplification of a small detected signals. A problems exist if the transistor itself is noisy as is such the case of the 2SC1674 when compared to other low noise packages. Along with the amplification of the incoming signals is transistor noise. Replacement of this transistor with a higher gain, lower noise transistor greatly improves the signal to noise ratio of your receiver.
The transistor Q8 operates at VCE= 6Volt and IE= 2,5mA. We will use an 2SC2999 transistor that has higher gain and lower noise characteristic. Replace
