Alinco has created a new UHF FM Hand held Transceiver that sets new standards in features,
convenience and easy operation. The DJ-496T sports an alphanumeric
display for easy memory management. It has an ergonomic design that's
"user friendly" and the 4 watt output battery is standard. You'll be ready
to travel the world with CTCSS encode+decode, DCS and European tone bursts,
all included at no extra cost. Best of all, the DJ-496T retains the
proud Alinco tradition of quality construction and excellent value.
Alphanumeric display
40 memory channels + Call Channel
Backlit Keypad
4 watt output with standard battery
CTCSS encode+decode and DCS
13.8 VDC direct input with battery charge feature
Direct frequency input
S-meter
Autodialer
Cable Cloning
Computer programmable (third party software required)
MARS/CAP capability
Additional features, including theft alarm!
| Alphanumeric Display | Label channels in an easy-reading format. Display frequency, alpha label or channel number only. |
| 40 Memory Channels + Call Channel | Plenty of room to store your favorite simplex or repeater frequencies along with alphanumeric label, offset, CTCSS encode/decode or DCS setting. |
| 4 watts output |
The standard battery allows the DJ-496T to produce up to 4 watts. A power input port Accepts 13.8 VDC and charges the battery, but won't allow destructive overcharge. |
| CTCSS, DCS, Tone Bursts and DTMF | Be prepared for virtually any selective calling situation or gaining access to repeaters with protected inputs. European Tone Bursts include 1000, 1450, 1750 and 2100 Hz. |
| Direct Frequency Input | Frequency entry is easy using the well-spaced keypad. |
| S-Meter | Displays relative signal strength. |
| Cable Cloning | Share identical settings among multiple DJ-496T transceivers. Saves time and ensures uniform operation. |
| Theft Alarm | The DJ-496T can be set to emit a tone when disconnected from an external power source until proper action is taken to silence the alarm. |
| Experimental Insect Repel Feature | Can the DJ-496T actually repel mosquitoes? Activate the special tone and decide for yourself! You may find the DJ-496T can "de-bug" your outdoor operating site! |
