      The World of HF Design has just
      taken a giant step!
      For more than half a decade the
      FT-1000 has been highly acclaimed by the world's top DX'ers. Now Yaesu has
      created a new HF masterpiece, building upon proven RF design techniques
      while introducing a new technology to the Amateur Radio market: Enhanced
      Digital Signal Processing. With its outstanding receiver section
      (featuring Collins Mechanical Filters), a clean and versatile transmitter,
      plus outstanding ergonomics, the FT-1000MP brings a new level of HF
      performance and design excellence to the world's most demanding amateurs.
    | Having long ago broken through the 100 dB receiver dynamic range
      barrier, Yaesu has now revolutionised the sophisticated area of digital
      manipulation of signal waveforms through the introduction of Enhanced
      Digital Signal Processing (EDSP). Through skillful software design and
      hundreds of hours of on-the-air evaluation, the Yaesu design team has
      created an impressive array of noise-reduction and interference-rejection
      filters never before available in the communications industry. Mindful of
      the critical need to preserve signal-to-noise ratio and IF skirt
      selectivity throughout the receiver, Yaesu engineers have retained the
      wide variety of IF filters and high- intercept front end which made the
      FT-1000D a best-seller Using this RF/IF design as a foundation, and the
      FT-1000MP's EDSP system and Collins Mechanical Filter, the result is a
      uniquely clean- sounding transmitter, receiver performance second to none,
      and a total communications package without peer in the Amateur Radio
      industry. |
    | Direct
      Digital Frequency Synthesis |
    | Two 10-bit and three 8-bit direct digital synthesisers are used in
      the FT-1000MP local oscillator system. Driven by a single TCXO master
      oscillator, these synthesisers produce extremely fine tuning in thirteen
      user selectable steps down to 0.625 Hz. The multiple DDS system provides
      pure local signals which form the foundation of the outstanding receiver
      and transmitter performance. A choice of optional TCXOs ensures
      state-of-the art stability--ideal for digital operations.  |
    | Shuttle-jog Tuning Knob |
    | The Shuttle-jog Tuning Knob may be routed in either direction and
      provides efficient QSY instead of spinning the VFO knob. The more the
      "jog" ring is moved from the center, the progressive frequency steps
      increase. The Shuttle- jog tuning steps and stepping speed are accessible
      from the Menu system. In addition to the revolutionary new Shuttle-jog
      Tuning Knob, the FT-1000MP has five other tuning methods, Main and Sub VFO
      Tuning Knobs, Direct Keypad Entry, Panel and Microphone Up/Down Keys and
      Memory/VFO CH Selector. |
    | Dual
      In-Band Receive |
    | Essential for efficient contest and split frequency DX operating,
      the Dual Receive feature of the FT 1000MP allows the operator to watch
      both sides of a pile up, or monitor QSOs on two different frequencies and
      modes within the same band. The Main and Sub VFOs can be placed in the
      "tracking" mode, allowing efficient diversity operation with a touch of a
      button. The sub-receiver has its own S meter, too!
    | Enhanced Digital Signal Processing
  (EDSP) |
    | The
      FT-1000MP introduces the Yaesu exclusive Enhanced Digital Signal
      Processing system to the world of HE operating. Operational both in
      receive and transmit modes, EDSP provides 4 random-noise reduction
      protocols, audio enhancement with 4 voice response equalisation programs
      for both RX and TX, and an automatic notch filter which identifies and
      eliminates multiple interfering carriers or heterodynes. Selectable
      contours of the EDSP bandpass filtering offer low, mid, and high- range
      roll-off responses, allowing the operator to cope with changing
      interference conditions. Improved signal-to-noise ratio, razor-sharp
      selectivity curves, and outstanding transmitted signal clarity are yours
      with the exclusive EDSP system.  |
          | EDSP IF
            Demodulating & Processing |
          | For SSB, CW and
            AM, the receiver 3rd IF output is applied to a special 10.24 kHz
            EDSP IF for demodulation and processing. The selectable digital
            bandpass filters provide optimised bandwidth and frequency response.
          | EDSP Noise
            Reduction |
          | In addition to
            a highly-effective dual mode IF Noise Blanker, the FT-1000MP boasts
            an EDSP Noise Reduction system with 4 noise reduction protocols to
            help with changing noise characteristics.  |
          | EDSP Contour
            Selections |
          | Unique DSP
            filter networks aid in QRM reduction. Select Low, Mid, or High-cut
            responses or band pass filters from the front panel. Use the
            different contour selections to enhance intelligence recovery under
            different interference situations.  |    |
          | EDSP RX
            Audio Equalisation |
          | Three EDSP RX
            equalisation contours provide the operator with unmatched
            flexibility in reducing interference.  |
          | EDSP TX
            Modulation and Equalisation |
          | Early-stage
            transmitted SSB audio is applied directly to EDSP circuitry for
            processing. EDSP fitter parameters can be matched to voice
            characteristics. The result is optimum audio tailoring and sound
            clarity!  |
          | EDSP TX
            Bandpass Filtering |
          | The EDSP system
            of the FT-1000MP allows selection of one of four low frequency cut
            off parameters, so as to provide the best match to the operator's
            voice characteristics.  |
          | EDSP Automatic
            Multiple Notch Filter |
          | Multiple notch
            capability within the AF passband is possible with EDSP. The digital
            notch circuitry continually analyses the AF passband and the
            correlation of the signals present, identifying and notching out
            heterodynes as they appear.  |    |
          | Collins Filters
           Well known since the early '505, Collins
            Mechanical Filters have dominated the high end SSB, CW and, AM
            filter market. The built in Collins Mechanical Filter operates at a
            center frequency of 455 kHz with a band width of 2.75 kHz (500 Hz
            Collins Mechanical Filter is optional. Collins Mechanical Filters
            ensure superior IF performance, thanks to their fiat passband
            response, excellent skirt selectivity and very low inter- modulation
            distortion. The Collins Mechanical Filters used in the FT-1000MP are
            manufactured to the same standards as those used by commercial
            airlines, ships at sea, and the armed forces. These filters are
            ideal for voice, CW or digital modes of operation.  |
          | Dual Receive
          | Both dual and monaural
            receive are possible with stereo headphones (YH-77STA). Headphone
            configurations include: * Mono-Both Main and Sub receiver audio
            combined equally in both ears. * Stereo 1-Main receiver audio in
            left ear; Sub receiver audio, right ear. * Stereo 2-Audio from each
            channel in each ear with Main receiver audio enhanced, left ear; Sub
            receiver audio, enhanced, right ear. Constant level stereo audio is
            also provided via the rear panel AF output jack.  |
          | AM Synchronous
            Tuning |
          Ideal for shortwave
            listening, the synchronous detection system of the FT-1000MP
            provides less fading and improved signal fidelity, compared to
            previous AM detectors. Additionally, both 2.4 kHz and 6 kHz IF
            filter bandwidths may be used in the AM mode. Or simply use the Dual
            Receive capability of the FT-1000MP on opposite sidebands (LSB and
            USB) as another method to reduce interference.  |
          | User-friendly
            Memory System  |
          | The FT-1000MP contains 99
            regular memories, 9 special "band limit" memories, and 5 QMB (Quick
            Memory Bank) memories. Each stores both RX and TX frequencies and
            modes, IF bandwidths, Clarifier status, and "split" status. All
            memories can be freely tuned or copied to another memory. The QMB
            feature allows storing a station quickly without overwriting one of
            the "Main" memories. |
          | World-Class CW
            Performance  |
          | The FT-1000MP is unmatched
            in its array of features especially designed for CW operation at the
            highest levels of competition. Included are: *Full break in keying
            with programmable envelope delay. |
            Built in electronic keyer with memory
            (external keypad required). |
            CW Spot for easy zero beating on desired
            stations. |
            CW Pitch control for BFO and side
            tone/spot frequency,
            adjustable from 300 to 1050Hz. |
            CW Reverse
            selection, allowing the use of either USB or
            LSB BFO injection. |
            2 key/paddle input
            jacks, one each on front and back panels. |
            CW Tuning Indicator on the Main
            display. |
          | CAT
            INTERFACE  |
          | The FT-1000MP
            is ready for direct connection to a computer's RS-232C serial port.
            The built in RS-232C computer interface of
            the FT-1000MP utilises a convenient DB 9 serial connector from the
            level converter. |
          | An
            "All-in-one" Performance Package  |
          | The FT-1000MP
            includes a compact switching regulator power supply, specifically
            designed for
            low noise and a wide
            acceptance of input voltages (90-129V and 180-258V). 13.5 V DC can
            also be supplied from an external power supply DC-only model
            (FT-1000MP/DC) also available. For base, emergency or DXpedition
            use, the FT-1000MP is ready for action.
          | Cascaded RF/IF
            Filtering  |
          In addition to 11 receiver
            input bandpass filters, the FT 1000MP includes 3 automatically
            selected high-pass filters which provide superb immunity from 2nd
            order IMD. IF filter selections can be cascaded to combat QRM and
            tailor received audio. With 2 banks of independently selectable
            filters, one bank each for the 8.215 MHz 2nd IF and 455 kHz 3rd IF
            the FT-1000MP provides the solid IF filtering required in today's
            crowded bands.  |
          | Dual Noise
            Blankers |
          | The Dual mode IF Noise
            Blanker provides outstanding rejection of narrow impulse type (NB1)
            noise or wider "woodpecker" type pulses (NB2). The blanking
            threshold is adjustable front the front panel.  |
          | Expanded Tuning
            Scale  |
          | The bargraph segment of the
            meter above the Main frequency display serves as a dual mode
            enhanced tuning scale, providing a visual indication of relative
            offset during Clarifier ("RIT") operation.
          | Multi-Colour
            High-Resolution Display |
          Never before has such a
            wealth of information been provided on a transceiver display. In
            addition to independent frequency and S meter displays for each VFO
            the display area indicates power output, PA collector current, SWR
            ALC level, RF speech processor compression and PA input voltage,
            microphone gain level as well as Clarifier offset, memory
            information, and directional tuning scale to assist in precise
            tuning. |
          | QUICK SPLIT
          | To expedite set-up of the
            FT-1000MP in a split DX pile up the "Quick Split" feature can be
            enabled from the menu system. Activated by the A B button, the Sub
            VFO is placed in the same operating mode as the Main VFO, separated
            by a convenient offset (e.g."up 5"). |
          | Versatile
            Scanning |
          | The FT-1000MP includes
            several scanning functions which are indispensable in keeping track
            of activity, These are: *Band Scanning, *Memory Scanning, *Sub band
            Limited Scanning. Certain memories may be "tagged" to be skipped
            during scanning, such as, for example, WW. The scanner will resume
            when the squelch closes or after a preset time delay.  |
          | 3 Antenna
            Connectors  |
          | The FT-1000MP
            provides 2 main antenna jacks ("A" and "B") with front panel
            selection of the best antenna for current conditions. Additionally,
            a separate RX only antenna such as a low-band loop may be connected
            to the RX ANT jack on the rear panel; the "A" or "B" antenna will
            then be used for TX and the low noise loop for RX.
          | Low-Noise
            Local Oscillator System |
          | Providing the
            foundation for the remark ably clean RX and TX performance, the
            local oscillator system of the FT-1000MP is the key component of an
            overall commitment to signal purity. High transmitter C/N ratio, an
            exceptionally quiet receiver, and quick
            switching time are the results of this design philosophy, while the
            conservative ratings of the 2SC2879 PA transistors ensure many years
            of trouble free competition grade performance.  |
          | Digital
            Mode Operation |
          | The FT-1000MP
            is ideal for digital modes! In addition to the dedicated
            input/output/PTT jacks for FSK and AFSK operation, the EDSP system
            includes 3 filters specially tailored for digital modes.
            Furthermore, the frequency display can be programmed to indicate
            either the center frequency of packet tone pairs or the actual
            carrier frequency. |    |
            SPECIFICATIONS |
                | GENERAL |
                   RX Frequency
                  Range:  |
                100 kHz ~
                  30 MHz |
                   TX Frequency
                  ranges:  |
                160 ~ 10m amateur
                  bands only |
                   Freq.
                  Stability:  |
                <±10 ppm (-10oC ~
                  50oC) |
                <±2.0 ppm (0oC ~
                  50oC) w/TCXO-4 |
                <±0.5 ppm (0oC ~
                  50oC) w/TCXO-6 |
                | Freq. Accuracy: |
                <±7 ppm (except FM
                  <±500 Hz) |
                | w/TCXO-4: |
                <±2 ppm (FM
                  <±460 Hz) |
                | w/TCXO-6: |
                <±0.5
                  ppm (FM <±460 Hz) |
                | Operating Temperature Range: |
                -10oC ~
              50oC |
                | Emission Modes: |
                LSB, USB, CW, AFSK,
                  FSK, AM, FM |
                | Frequency Steps: |
                0.625/11.25/2.5/5/10
                  Hz for SSB, CW, RTTY & Packet; 100 Hz for AM and
                FM |
                | Antenna Impedance: |
                50 Ohm
                  Unbalanced |
                | Supply Voltage: |
                90 ~ 129, 180 ~ 258
                  VAC, 50/60 Hz and 13.5 VDC |
                DC-only model also
                  available (FT-1000MP/DC) |
                | Power Consumption (approx.): |
                2.4A RX (No Signal)
                  2.8A RX (signal) |
                19A TX (100
                  Watts) |
                | Dimensions (WHD): |
                410 x 135 x 347
                  mm |
                (16.4 x 5.4 x 13.9
                  in) |
                   Weight
                  (approx.):  |
                15 kg. (33
                lbs.) |    |
                | TRANSMITTER |
                   Power Output:
                adjustable up to 100 watts |
                (25 watts AM Carrier) |
                   Duty
                  Cycle:  |
                100% @ 50 watts, 100% @ 100 watts |
                (FM & RTTY, 3-minute TX) |
                | Modulation Types: SSB: |
                J3E Balanced, Filtered Carrier |
                | AM: |
                A3E Low level (early stage) |
                | FM: |
                F3E Variable Reactance |
                | AFSK: |
                J1D, J2D Audio Frequency Shift Keying |
                | Maximum FM Deviation: |
                ±2.5 kHz |
                | FSK Shift Frequencies: |
                170, 425 and 850 Hz |
                | Packet Shift Frequencies: |
                200, 1000 Hz |
                | Harmonic radiation: |
                at least 50dB below peak output |
                | SSB carrier suppression: |
                at least 40dB below peak output |
                | Undesired sideband suppression: |
                | Audio response (SSB): |
                not more than than -6dB from 400 to 2800
Hz |
                | 3rd-order IMD: |
                -31dB @ 100 watts PEP, or better |
                | Microphone impedance: |
                500 to 600 Ohm |
                | RECEIVER |
                | Circuit type: |
                quad-conversion superheterodyne |
                (triple
                  conversion for FM) |
                | Intermediate Frequencies: |
                      | Main
RX |
                      Sub
                    RX |
                      | 70.455
                      MHz |
                      47.21
                      MHz |
                      | 8.215
                      MHz |
                      455
                    kHz |
                      | 455
kHz |
                      | 10.25 kHz
                        (EDSP) |
                | Sensitivity (For 10 dB S/N): |
                      | IPO |
                      ON |
                      OFF |
                      OFF |
                      OFF |
                      | Freq
                         Mode   |
                      150 ~ 250 kHz |
                      250 ~ 500 kHz |
                      0.5 ~ 1.8 MHz |
                      1.8 ~ 30 MHz |
                      | SSB, CW (2.4
                        kHz) |
                      5
                        uV |
                      4
                        uV |
                      2
                        uV |
                      0.25 uV |
                      | AM (6
                      kHz) |
                      40
                        uV |
                      32
                        uV |
                      16
                        uV |
                      2
                        uV |
                      | 29 MHz FM (12 dB
                        SINAD) |
                      0.5
                        uV |    |
                | Selectivity (-6 / -60 dB): |
                      | Button |
                      Modes |
                      Min -6dB BW |
                      Max -60 dB BW |
                      | 2.4 kHz |
                      all except FM |
                      2.2 kHz |
                      4.2 kHz |
                      | 2.0 kHz |
                      all exc. AM, FM |
                      2.0 kHz |
                      3.6 kHz |
                      | 500 Hz |
                      CW, RTTY, Packet |
                      500 Hz |
                      1.8 kHz |
                      | 250 Hz |
                      CW, RTTY |
                      250 Hz |
                      700 Hz |
                      AM (Wide) |
                      4 kHz |
                      14 kHz |
                      FM |
                      8 kHz |
                      19 kHz |    |
                | Dynamic Range: |
                108 dB (@
                  50 kHz, 500 Hz BW, RF amp off) |
                | Squelch sensitivity: |
                | 1.8 ~ 30 MHz: |
                (CW, SSB,
                  AM): <2.0uV |
                | 28 ~ 30 MHz: |
                (FM):
                  <0.32uV |
                | IF rejection (1.8 ~ 30 MHz): |
                80 dB or
                  better (Main RX) |
                60 dB or
                  better (Sub RX) |
                | Image rejection: (1.8 ~ 30 MHz): |
                80 dB or
                  better (Main) |
                50 dB or
                  better (Sub) |
                | IF shift range: |
                ±1.12
                  kHz |
                | Max audio output: |
                1.5W into 4
                  Ohms with < 10% THD |
                | Audio output impedance: |
                4 to 8
                  Ohm |    |
