             Just as the Internet has
              ushered in a new era of computing, APRS® has added a new dimension
              to radio communications. And you can experience it all with Kenwood's
              new TM-D700A/E.
            One of the greatest pleasures of exploration is being able to communicate
              each new discovery. And Kenwood's TM-D700A/E Data Communicator allows
              you to do just that. This FM dual-band mobile transceiver harnesses
              APRS®, GPS and SSTV technologies to provide world-class communications
              for the Great Outdoors.
            As smart as Kenwood's new TM-D700A/E is -- with its extra-large
              amber & black display (reversible) -- it is even smarter inside.
              This new-generation mobile transceiver features a built-in TNC to
              offer a wide range of data communications options, including simple
              packet operation using the AX.25 protocol. You can even send and
              receive SSTV images (using Kenwood's VC-H1). But above all the TM-D700A/E
              is fully equipped to make the most of APRS® -- the Automatic
              Packet/Position Reporting System.
 Features at a glance:
            TM-D700A/E
              in detail:
            Kenwood Skycommand System (KSS) II*
              Thanks to Kenwood Skycommand System (KSS) II, you can be mobile
              and yet enjoy full access to the HF transceiver back home in your
              shack. All you need to do is hook up the Transporter (a TH-D7A or
              TM-D700A, for example) to your TS-570D/S(G) or TS-870S HF transceiver.
              You can then use your TM-D700A as the Commander, transmitting control
              signals to the Transporter, which also relays your voice to the
              HF radio. In return, HF signals are transmitted back to the Commander.
            This system allows you to transmit and receive HF signals, set
              frequencies (with LCD confirmation), switch memory channels, and
              much more -- all from your mobile transceiver. Kenwood Skycommand
              II enables full-duplex operation with access to such HF functions
              as XIT/RXT, mode switching (USB, FM, etc.), split-frequency operations
              on/off, memory shift, and frequency step selection. In addition,
              once every 10 minutes, the Transporter (TH-D7A) will send out its
              pre-programmed call sign via CW.
            *TM-D700A North American model
              only.
            APRS® (Automatic Packet/Position Reporting System)
              The TM-D700A/E has everything you need to explore the exciting
              possibilities of APRS® -- and you don't even have to own a computer.
              If you know your current position, you can manually input latitude
              and longitude data for transmission to other members of your group
              or to anyone using APRS®. Of course, a GPS unit will effectively
              do this for you, and ensure accuracy. When you receive a friend's
              coordinates, you can display latitude/longitude, direction and distance
              on your own Data Communicator. Like all of the best ideas, in both
              conception and execution APRS® is beautiful in its simplicity.
            APRS®
              Features:
                   Positional/directional data
                    With an NMEA-0183 compatible GPS receiver you can transmit
                    your exact position for automatic calculation of distance,
                    current speed and heading. Any of the last 4 digits can be
                    masked for variable "position ambiguity" if you
                    wish to limit accuracy. You can also limit your own APRS®
                    reception from a maximum range of 2,500 miles to just 10 miles.
                    Unprotocol
                    When you need to focus, this function allows you to control
                    what data you receive. Choose all calls, special (events),
                    or alternate net (group code).
                   Versatile messaging
                    Transmission of position data can be accompanied by position
                    comments (15 selectable settings), 5 programmable status texts
                    (up to 28 characters), icons, and bulletins. For added messaging
                    flexibility, individual alpha messages (up to 64 characters)
                    can also be sent. Internal memory can store up to 16 transmitted/received
                    messages.
                   Station list
                    Received APRS® data can be stored in up to 40 memory channels
                    for listing on the LCD display. You can pick any one to see
                    full details of a station's status (fixed, moving, weather,
                    etc.), as well as its position and heading.
                    Grid square locator
                   TX interval (0.2/0.5/1/2/3/5/10/20/30 min.)
                    Packet path selection with Digipeat
                   Weather station & Power Height Gain (PHG) data reception
                   Digipeat function capability
                    Auto Message Reply
                   Audible APRS® message receive (call sign) notification
                    (requires VS-3)
                 Waypoint position data output  |
            TM-D700A/E + VC-H1 (Visual Communicator)
              The Kenwood VC-H1 Visual Communicator, which combines an image-scan
              converter and CCD camera in a compact battery-operated unit, makes
              it easy to receive and transmit color pictures -- whether a majestic
              mountain panorama or just a self-portrait. Simply connect the VC-H1
              to your TM-D700A/E to start sending and receiving color images over
              the air.
                Image memory (VC-H1)
                  Up to 10 pictures can be stored in memory. This allows you to
                  compare and pick the best shot to send. You can also store incoming
                  pictures and protect them from unintentional deletion.  |
                Fast FM mode (VC-H1)
                  This high-speed transmission mode lets you send an image in
                  14 seconds (approx.) |
                SSTV transmission mode selection
                  (VC-H1)
                  You can select either Robot 36 or Fast FM mode.  |
                Simultaneous reception of voice & image transmissions
                  (VC-H1)  |
            Other Features:
              only.
            Dimensions (W
              x H x D)
                   Body: projections not included
                    5.51 x 1.58 x 7.68 inch (140 x 40 x 195 mm)
                  Panel: projections not included
                    5.51 x 2.36 x 1.31 inch (140 x 60 x 33.3 mm)
              Operation of DTMF and CTCSS is subject to local regulations.
