 From the extra-large control panel - with the welcoming glow of its amber-colored LCD - to Kenwood's new Easy Operation mode, the TM-G707A/E is extraordinarily user-friendly. That, after all, is a design imperative for mobile communications equipment. But this FM dual-band (2m/70cm) transceiver goes well beyond the call of duty, offering a "five-in-one" programmable memory, a Memory Name function, and numerous other features that make operation more natural than ever. Optimized convenience goes hand in hand with the polished performance of the TM-G707A/E.
 Features at a glance:
High-visibility 7-character display |
Easy Operation mode |
"Five-in-one" programmable memory  |
180 multi-function memory channels  |
Memory Name function  |
Multi-scan functions  |
Priority scan  |
Built-in CTCSS encoder/decoder  |
Quick-release detachable front panel kit (option)  |
Selectable frequency step (5, 6.25, 10, 12.5, 15, 20, 25 or 50kHz)  |
Voice Guide (requires VS-3 option)  |
AIP (Advanced Intercept Point)  |
Heavy-duty construction  |
TM-G707A/E in detail:
High-visibility display
Capable of displaying up to 7 large alphanumeric characters - in either frequency or Memory Name mode - the positive-type amber LCD comes with a 4-step dimmer control to suit all driving conditions, day or night. A thoughtful touch is the automatic brightening during operation.
Easy Operation mode
This mode allows the transceiver to be operated as easily as a car radio. You simply choose a frequency and press one of the 3 memory keys for one second to save it. A light touch on the same key is all that is required for recall, after which the encoder can be used to tune above or below that frequency.
In addition to its regular profile, the TM-G707A/E can store four other operating profiles - complete with frequency range, dimmer level, and other details - ready for instant recall at the push of a button. You can further choose automatic updating of the current profile if you wish.
There is no shortage of capacity: 180 memory channels are available for storing such important data as transmit and receive frequencies (independently, thus allowing split-frequency operations), frequency step, and tone frequency.
A convenience that is especially welcome for mobile applications is this function which, as its name suggests, allows you to identify each of the 180 channels with up to 7 alphanumeric characters. You can also switch instantly between the frequency and Memory Name displays.
User-friendliness is further enhanced by full band and programme band scans, memory scan with memory channel lock-out, MHz scan and call scan. For each band there are TO (time-operated) and CO (carrier-operated) scan stop modes.
Priority scan function
Of special note is priority scan, available in two modes: choose mode A to check every 3 seconds, whether or not the displayed frequency is busy; or choose mode B to check at the same interval, but only when the displayed frequency is not busy.
The CTCSS (Continuous Tone Coded Squelch System) encoder/decoder enables operation of the 38 EIA-standard CTCSS subtone frequencies including tone scan.
6-pin mini DIN connector for 1200/9600bps packet
The front panel features a connector for hooking up to a TNC, enabling either standard 1200bps or 9600bps high-speed packet communications. This same connector can also be used for PC programming of the transceiver.
If you are concerned about security, simply remove the compact front panel whenever your vehicle is left unattended. If one of the 3 optional quick-release kits is used, the panel can be mounted virtually anywhere since the microphone cable connects directly to the main unit.
Other Features:
CTCSS receive tone frequency display  |
Superior intermodulation rejection characteristics  |
Incremental MHz key  |
Memory shift  |
S-meter squelch  |
Power-on message  |
3-position RF output power control  |
Dimmer control  |
Time-out timer (TOT)  |
Auto power-off circuit  |
1750Hz tone burst (E type) |
Dimensions (W x H x D)
140 x 40 x 189 mm (5.52 x 1.58 x 7.45 in.)  |
Operation of DTSS, Pager, DTMF, and CTCSS is subject to local regulations.   |
